Microvellum Foundation Library Release Notes | Build 22.0317
The following release notes apply to Microvellum Foundation Library, Build 22.0317
Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial.
Additions:
  1. Added third split to Master Split Corner Cabinet
  2. Added Tall Split Cornet Pantry
  3. Added Inner drawer to 1, 2 and 3 drawer cabinets
  4. Added Drawer Grain Direction to Door-Drawer Cabinets
  5. Added Grain Direction to Applied Back Panels
  6. Added Shelves with Shelf Standards product
Resolutions:
  1. Resolved Machining and Part sizes in Transition Cabinets
  2. Resolved issues with overlay bottoms and Tops placement and size in Diagonal Angle Cabinet
  3. Resolved the excess bottom drawer gap for all system drawer as it was not linked to the global "Drawer Box Fixed Locations" variable. This was causing the drawers to sit up too high from the bottom of the drawer front.
  4. Resolved an issue within the F Workbook table- Bottom drawer gaps were coming in as a negative value.
  5. Resolved an issue with Grass DWD XP - Pot-Drawer min height was incorrect
  6. Resolved an issue with Top Drawer Front Height Prompt not showing in Door-Drawer cabinets
  7. Resolved an issue with the Applied ends not showing on 2D drawing Plan view
  8. Resolved an issue with Filler and Applied End edging in the finish face subassembly. The edge was only looking at base door edges
  9. Resolved an issue with the Door Drawer Component Subassembly- Bottom hinge prompt name error and removed the calculator which is not needed. Also unhid the Top drawer front height prompt.
