Microvellum Foundation Library Release Notes | Build 22.0407
The following release notes apply to Microvellum Foundation Library, Build 22.0407
Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial.
Additions:
  1. Added the ability to change lock type for drawers in Door-Drawer Cabinets
  2. Added Rear Cutout Option for Wood Drawer box
  3. Added Pointers to the material files for the applied shelf edge.
  4. Added Grain Direction prompts to the Applied Back Panel products.
  5. Added K height sides to the Tandembox Antaro drawer subassembly.
  6. Add Secondary Locks to door subassemblies (elbow catches, etc.).
  7. Added Krome Linea Drawer System
  8. Added DTC Smooth Drawer System
  9. Added file options to the Wood Drawer Box
Modifications:
  1. Changed the way the Left Applied End and Applied End prompts in the subassembly are getting turned on by the local product. Now using bay positions instead of the Prompt Values. This stops the issue of getting two panels when saving subassembly to project.
  2. The countertops that are drawn on products have been remastered; the countertop's overhangs are now calculated in the Subassembly instead of the local product.  In the local product the countertops now just equal the product width and depth. Also, x and y origins are set to 0.
  3. All drawings related to the rod handles have been updated.
  4. The global "Text_Style_Options' list has been updated with text styles from the drawing templates.
  5. Updated Reports & Labels
Resolutions:
  1. Updated all Wire Curved and Straight Pulls' 2D graphics file names to match the updated database names. This was preventing them from showing in 2D.
  2. Resolved an issue with the Profile Doors - the Perfect cornering was hard valued to metric.
  3. Reduced the 2d Plan dim lines in the Fillers as they were coming from the front of the cabinet. They now line up with the Cabinet width dim lines.
  4. Resolved an issue with the machining on the Straight Blum Expando Mounting Plate. The hole diameter was 10mm and should have been 5mm.
  5. Resolved an issue with the MV Profile Door Subassembly where the profile would not show in 3D when all edges of the panel had a profile.
  6. Resolved an issue where the drawer boxes were not offsetting in the Z when using the global prompt "G!Drawer_Stretcher_Offset".
  7. Resolved several issues with the Suspended cabinets.
  8. Resolved a 3d graphics issue with the Solid Wood Door when using Arched Raised Panel
  9. Resolved several issues with the 2d drawings when using tab pull handles
