Microvellum Foundation Library Release Notes | Build 22.0520
The following release notes apply to Microvellum Foundation Library, Build 22.0520
Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial.
Additions:
  1. Added lighting options to the under panel in the Upper Undermount Rangehood cabinet
  2. Added Edge Bore Parameters to Hardware Array
  3. Added “Top & Bottom” as a placement option for Secondary Lock location
  4. Added the ability to individually adjust the top and bottom door heights in the Aventos HF Liftup Door system
  5. Added a Countertop with sink options to the ADA Single Angled Frame product
  6. Added a subassembly called “A New Subassembly” to be used when needing to build a new subassembly from scratch.
  7. Added sample horizontal bore toolfiles
  8. Added additional drawing blocks category for "Wood Products".
Modifications:
  1. Upper Scribe Filler bottom return is now pointing to Filler_Material as the material
  2. Renamed the default sample toolfiles to include Metric or Imperial
Resolutions:
  1. Resolved an issue where the Master Cabinet with 1 Drawer selected draws 2 Drawers
  2. Resolved an issue where Tab-Pull handles with rebate would not machine past the edge of the associated part
  3. Corrected the tool compensation for the Italiana Libra H1 wall hangers
  4. Resolved an issue where the 2D elevation and cross-section of “Pull Knob” and “Handle Hettich Alumus Knob” were not scaled correctly in Imperial units
  5. Resolved an issue where the Hafele Cabinet Hanger Short 3D block graphics were rotated incorrectly
  6. Resolved an issue with Drawer Divisions where the rail notch machining was being offset incorrectly
  7. Resolved an issue where some Base Points in the MV Profile Door were incorrect for bay positions 77 and 80
  8. Resolved an issue that affected some hinge plates on some drop down door conditions.
