Microvellum Foundation Library Release Notes | Build 22.0625
The following release notes apply to Microvellum Foundation Library, Build 22.0625
Additions:
  1. Added Access Panel Subassembly (from legacy component library)
  2. Added the prompts "Extend Left Side To Floor" and "Extend Right Side To Floor" to all cabinets. Also have added a global to turn this on as default for every cabinet.
  3. Solid wood doors will now show the 3D door swing
  4. Added opening calculator for Inner Drawers
  5. Add the Ability to change Continuous Shelf Hole Condition in Subassemblies. Added the prompts "Continuous Shelf Hole Condition" and "Continuous Shelf Offset". You can now change the Continuous Shelf Hole Condition from fixed to Centred in the subassemblies. When Centred is selected the Continuous Shelf Offset is used, as the offset from the top and bottom will be the same. When it is set to Fixed, "Continuous Holes Distance From Top" and "Continuous Holes Distance From Bottom" are used.
  6. Added Diagonal Crown Molding for Diagonal cabinets
  7. Added a global prompt to control if we want a corner notch relief or not on applied toe kicks with notched ends
  8. Added the option to have a finished end with a notched toe kick when using adjustable legs (or other type of toe kicks) by default.
  9. Added Under Stair Cabinets
    1. Under Stair 1 Door
    2. Under Stair 2 Door
    3. Under Stair Vertical 2 Bay Cabinet
Modifications:
  1. Updates & Improvements to Metric & Imperial DWT files
    1. Cleaned out (simplified) Imperial Dim Styles and text styles
    2. Updated Appliance layer names to match data (3D_STAINLESS APPLIANCE to 3D_STAINLESS STEEL APPLIANCE)
    3. Corrected default imperial zoom factor
    4. Glass layers should now have transparency values
    5. Line types should be by layer instead of by block
  2. Moved three categories out of Frameless Cabinetry: Countertops, Miscellaneous, Parts
  3. Sink subassembly Finish Options now to be "BLACK|WHITE|STAINLESS STEEL" to match layer naming convention.
  4. Part & Product Labels now include the Project Level Prompt called “Region”, which flips WxL to LxW for AU and NZ.
Resolutions:
  1. Resolved an issue with Tall Wall Oven and Tall Wall Oven With Microwave: Side turning off when selecting Applied ends.
  2. Resolved an issue with Master 2 Bay Horizontal Cabinet, Master Horizontal Designer Cabinet: Top drawer was not drawing when no door is selected
  3. Resolved issues with Upper Undermount Rangehood Cabinet:
    1. Under Panel and Vertical Splitter parts not adjusting in Z for bottom valance
    2. Rails option for the top type will have a full top and a front rail
    3. Under Panel Overhang Left/Right prompts still visible when under panel is disabled
  4. Resolved an issue with Diagonal Corner Cabinets: Crown moulding doing both pie cut and diagonal shapes
  5. Resolved an issue with MV Profile Doors - The pattern selection for all 8 panels will change to a square pattern if the pattern is under 2x the pattern height.
  6. Resolved issues with Corner Base moulding when using Running Toe Base
  7. Resolved an issue with incorrect hinge selection on angled right-hand doors
  8. Resolved issues with Blind Corner Cabinets - Incorrect Bay Position number for Upper Right Door Using a Blind corner Hinge
  9. Resolved an issue with Drawer Spacers Z origin when using Wood Drawers
  10. Resolved an issue with Cabinet Modifications - Chamfers Not cutting chamfer on sides for open cabinets
  11. Resolved an issue with Open Upper cabinet missing crown moulding option
  12. Resolved an issue with Plants product in Accessories - not all blocks were scaling correctly in imperial
  13. Resolved an issue with Work Order Summary report. Updated data & columns to reflect proper formatting for edgebanding LinFt or LinMeters.
  14. Resolved an issue with Product Detail Report and all Product Labels. Adj Shelf Values are now to count the Adj Shelf from the Parts table instead of prompts.
