Microvellum Foundation Library Release Notes | Build 22.0729
The following release notes apply to Microvellum Foundation Library, Build 22.0729
Additions:
Added “No Back” options to the dropdown list under the “Back Construction” prompt. This will remove the back from the product.
Vertical Splitter Subassembly - Added options for a timber lip to the front of the shelf.
Added Support for CutRite Perfect Grain to relevant products.
Added “LibraryName” prompt to all products.
Modifications:
Inner Drawers Subassembly – Changed the calculator so that it calculates from the top down to keep it in line with the standard drawer cabinets.
Changed the way we search for wood drawers to just search for wood in the name, this way we can add more types of wood drawer subassemblies and the relevant prompts will appear when needed.
Resolutions:
Countertops Left L and Right L shape – Resolved an error with the Mason mites creating name errors in the product.
Master Wall Oven Cabinet – Resolved an issue with the top cabinet being out of position when changing the fixed shelf material.
Tall double door cabinets – Resolved an issue with the shadow rail being placed in the incorrect position between the top and bottom doors.
All Cabinets – Resolved an issue with back disappearing when selecting overlay Tops due to a name error in the “Top_Capture_Deduction” prompt.
Resolved an issue where the “Pocket Toe Kick” prompt was not looking at the global prompt.
Resolved an issue where the top and bottoms are coming out short if the nailer and back materials were different thickness.
Resolved hard values in the lookup table of the sink subassembly
Resolved an issue where the mirror function was only working on left doors not right doors.
MV Profile Door - Resolved an issue with the profile cut-outs coming out incorrect size.
Inner Drawers Subassembly – Resolved an issue with the bottom drawer being added twice.
Countertop With Substrate – Resolved an issue with the “Substrate_Setback“ Prompt Hard valued metric value.
Resolved issue in Drawer Box Report. Width and Depth are now the actual drawer box size, not the subassembly size.
