Microvellum Foundation Library Release Notes | Build 22.0902
The following release notes apply to Microvellum Foundation Library, Build 22.0902
Additions:
- Added Titus Tekform & Tekform Slimline Drawers.
- Updated/added EMF labels for all types. Metric sizes have the AU/NZ flag turned on so
the WxL dimensions are reversed.
- Added Finished Leg & Finished Leg w Radius products from legacy
library.
- Added Dovetail Drawer option.
- Added Product Group "Kitchen Island Group”.
- Added "Finish Face Edges" prompt to all cabinet products
to aid with the XML import tool.
- Added 44 new global variables and six new material pointers to
support a future Staircase expansion.
- Added “Lock Dowel E3259BM Channel Lock” as a new Hardware Array
option.
Modifications:
- Updated the Sawing Optimization Report.
- Made numerous changes and updates to most of the drawer systems to
match manufactures’ specifications.
- Updated the list of available drawer options.
- Inner Drawer (Rollouts) Spacers will now automatically turn on to
avoid door hinges.
- “Lock Drop Front” option in Wood Drawers will now automatically
activate with locked drawers.
- Vertical Front Rail option will now use the new material pointer
"Sub Front" for the Front Stretcher parts. This will now allow a
different material to be used for the Vertical Front Rails (Sub Fronts).
- Added two global variables to separate control of Overlay/Full
bottoms for Upper cabinets vs Base/Tall.
- Updated Hardware Array machine tokens to support a
"Mirrored" hardware item such as Lock dowel.
- Drawers in Face Frame Cabinets now set to frame opening width
instead of carcass opening (Face Frame Expansion).
- A new global variable was added to
set the threshold amount for the Inside Face Frame Overlay. This allows the drawer slides to tuck behind the face frame and bump the Cabinet Side or
Partition.
- Updated the factory table “LookUpTableSystemDrawerSlide” to contain
values more “friendly” to imperial users.
- Updated the factory table “LookUpTableDrwSlideAccuride3834” to match
manufactures' product codes.
Resolutions:
- Resolved issue within the Sawing Optimization Reports.
- Resolved issue within Drawer Box List Report to correct drawer box
size problem.
- Resolved issue with slide hole locations at inset drawer condition.
- Resolved Issues with Drawer Dividers when used with the Shadowline
Feature.
- Resolved issue when using the Generic Five Piece doors, the door parts no longer get included in the 2d face frame images (Face Frame Expansion).
- Resolved issue with Intermediate Rail 1 Z Origin in Face Frame
cabinets. Issue triggered when a value was added to Face Frame Top Overlay
