Microvellum Foundation Library Release Notes | Build 23.0113
The following release notes apply to Microvellum Foundation Library, Build 23.0113
Additions:
  1. Implemented a "Push Catch All Doors" option in the Hardware Wizard.
  1. Added the "Magnetic Catch Liberty" hardware option as an alternative choice for push catch.
  1. Introduce "Product Version" and "Subassembly Version" fields as a new prompt to help users keep track of the version of each product and subassembly they are using in their library.
  1. Incorporated a new "Shelf Clip Gap" variable in all adjustable shelf subassemblies, giving users more control over the fit of the shelves.
  1. Added hardware materials for Hafele Matrix Box S and Matrix Box Slim.
Modifications:
  1. Updated the Default Push Catch option to include catches at the top and bottom of Tall Cabinet doors.
  1. Blind Facia and Corner Filler parts inside Blind Corner Cabinets will no longer be affected by the top/bottom reveal variable as the doors do and will now remain at the height of the cabinet.
  1. Enhanced the shelf and 2D instructions subassemblies to search for the word "Glass" in the product description and use this information to determine which parts to show or hide in 2D elevations.
  1. Adjusted the countertop/benchtop products so that the part widths will now be the product depth, and the part lengths will now be the product widths, to improve compatibility with grained materials. Additionally, refactored and updated all mason miter polyline tokens to use VECTOR and PNT functions.
  1. Renamed the majority of office furniture products to make them easier to distinguish from regular Foundation Library Frameless products. To update Office Furniture products, it's recommended to delete the existing products first.
Resolutions:
  1. Fixed an issue with the cabinet nailer dowel machining.
  1. Fixed an issue with the quantity of shelves in Open Diagonal Angle Cabinets.
  1. Resolved an issue with the Drawer Front Calculator within the "Component Drawers FF" subassembly.
  1. Fixed an issue with the location of drawer slide holes in the Wood Dovetail Drawer Box subassembly.
  1. Addressed an issue with the Z origin location of Dovetail Drawers when used as rollouts with spacers.
  1. Fixed an issue with door/drawer cabinets when the "Use Rail Notch" option is unselected.
  1. Enhanced the global variable "Drill Through at Division for Shelves" to now control the "Division with Adj Shelves" subassembly.
  1. Tall and Upper Corner cabinets are no longer controlled by the global Shadowline option.
  1. Addressed an issue with certain face frame cabinets when using the "Tall Face Frame Sides Full Height" feature, which now extend to the floor when using the Notched Toe Kick option.
  1. Improved Mitered Shelf product to respond correctly when using the Mirror Product feature.
  1. Fixed issues with the Shelf Edge feature when using the Hardware Edge Array connecting option.
  1. Resolved notch issue when selecting a rotated wrapped batten.
  1. Fixed an issue with certain router bit drawings caused by extra line entities (Ogee 12P7 TW7506.dwg and Bead Cutter 3P2 TBB4 half.dwg).
  1. Addressed an issue with captured backs in Any Angle Cabinets
  1. Resolved an issue with the Cabinet Faces Only product, the Drawer Front Calculator now functions properly with all drawer quantities.
