Richelieu RCS Hinges (qty 13) and plates (qty 12) have been added, in a separate file. To download this file, contact Microvellum.
A prompt has been added in the Blind Corner FF Cabinets, giving the option to add a drawer mid-rail in the blind corner opening. The Face Frame subassembly has been updated to accommodate this extra rail.
A new prompt, "Rebated_Blind_Corner_Panel" has been added to the Blind Corner cabinets prompts on the main tab. This will sit the blind corner panel on the front of the cabinet with no rebates into the top and bottom panel.
A global prompt has been added that enables control over the adj shelf position relative to the shelf holes. The logic has been added to all adj shelf subassemblies.
Added “Shelf Support Route Machining Feature”. Shelf pin slots have been added to the adj shelf subassemblies and can also specify a drill hole.
A new option has been added to the Lift-Up Door list: "Top Hinge Only".
A small assortment of sample Flush Recessed Pulls (Oval, Rectangle, Round) has been added.
Added legacy generic Lazy Suzan pullouts for corner cabinets. Includes Corner Round and Full Round trays in numerous sizes from 12” to 32”.
Additional Metric Rebated Tab Pulls have been added in.
Modifications
Machining for notches and chamfers on Corner Cabinets has been modified to only machine on face 6 when necessary.
A new variable has been added: a mid-drawer overlay for the Master Cabinet FF and the Door Drawer FF Cabinet. When using a double-top drawer you can now control the overlay on the mid-stile.
“Farmhouse Sink Face Frame” - added a full sink rail prompt so that the top rail will be the height of the farmhouse sink.
Any Angle Cabinets now have angle validation codes to limit what's possible (110° -179°). Also added additional validation when the angle is less than 110° and the depth is greater than the “Back_Width_Left” and “Back_Width_Right”.
Added a search function for Shelf Adj and Shelf Fixed in the control types for all prompts relating to Adjustable Shelves and Fixed Shelves. This will allow for custom subassemblies for adjustable and fixed shelves.
Upper Microwave Cabinet – this appliance now has a Radius Control variable for Extended Bottoms.
The default location of Hanging Rails inside closet products has been modified. When creating closet products, the system will now reference the entered global variable instead of calculating “Inside_Width/2”.
For the search function to allow for custom subassemblies, custom shelves are required to have the shelf type in the name for this function to work properly: "Shelf Adj" for adjustable shelves and "Shelf Fixed" for fixed shelves.
Resolutions
The hardware materials kits for the Formed Javabox Drawer System have been added, in addition to minor issues being resolved.
The Grass Dynapro 40-70kgSoft-Close has been made available to clients in the UK region.
Lift-Up Doors now have 2D plan drawings available.
The Base Island Box End product has had several minor issues resolved, and in addition to a rendered image being added in for the product.
Blind Corner products had a noticeable issue involving the drawer box depth. This issue has been resolved, and to ensure it is not an issue in the future, the prompt "Drawer_Cabinet_Modification_Deduction" has been added into the data.
An issue within the vertical starter cabinets (such as Tall Wall Oven) that affected bay opening component Z origins in certain conditions has been resolved.
An issue in the Base 3 Door product that affected hinge plates and their associating to appropriate parts.
Resolved Metric/Imperial issue in solid wood doors that affected the 3D representation of cathedral shaped doors.
Dado tokens on partitions have been updated with “Thickness_Division” instead of using “Thickness_Left_Side” for parameters 5 and 6.
For all Corner Cabinets, the screw machining tokes have been updated on the thick backs to drill from the other side when the “=Construction_Method="Dado"” or “Construction_Method="Dado&Screw".
Issues have been resolved with the MV Profile Door. The groove 10-20 machine tokens for the grooves on all panels have been updated.
Cabinet top and bottom screw machining in the thick backs has been updated to turn off when using finished tops and bottoms.
Resolved a lock issue within the Office Furniture 1 Drawer Cabinet.
Resolved an issue with Office Sliding Door Credenza involving the inset doors and the size of the sides.
An issue with crown molding miters at transition Angle Cabinets has been resolved.
Resolved a reported issue with Rollouts/Inner Drawers colliding with the face frame bottom rails. If the rollout insert is in a face frame opening, then the "Bottom_Drawer_Position" value will increase by an equal amount as the “Face_Frame_Bottom_Overlay” value.
An issue within the subassembly insert Inner Drawer With Components Above was noted, wherein the Z origin for the nested insert subassemblies was incorrect, due to failing to account for the fixed shelf thickness. This issue has been resolved.
An issue in the Wooden Drawer Box that appeared when the Rear Cut Out feature was used has been resolved.
An issue was noted with drawer stretchers, in certain circumstances, causing unwanted machining in a nest. It’s been resolved- the drawer division and the blind corner hinge panel have been modified to be one part. This was achieved by adding a corner cutout in the Horizontal Splitter, controlled by a prompt value in the product. A new subassembly prompt has been added: "Blind_Corner_Hinge_Panel_Notch_Height".
Rear cam machining tokens on all fixed shelves and divisions have been updated. They will now respond to “G!Cam_Drill_Through_Backs”.
Resolved an issue within Blum LEGRABOX, which prevented the F height from populating the subassembly automatically.
Resolved an issue within certain closet products, which prevented the “Add Hanging Rail Right” prompt from appearing.
Resolved an issue with Nover Krome Premium drawer. The brackets and back drill now function correctly.
Resolved issues with the Blum TANDOMBOX Antaro drawer system.
Resolved an issue with the Hettich Innotech Atira’s inner drawer option.
An issue with the Grass Nova Pro Scala Inner Drawers has been resolved.
Resolved an issue with DTC Dragon Pro drawer system missing fixing bracket graphics. The graphics have been added and will display.
Resolved an issue with the Harn Ritma Cube drawer system.
There was a noted issue with the Integrated Dishwasher appliance not being placed correctly with applied ends. This issue has been resolved.
Resolved an issue with Adjust Shelves subassembly that occurred when inserting the shelves with “Pick Corners” as the method. In certain cases, the continuous linebore holes would not appear on the right.
Resolved an issue with the Access Panel subassembly insert. The innerworkings of the subassembly have been simplified using the OFFSETPOLYLINE function.
Resolved an issue with drawer front locks appearing when “Lock Drawer” prompt was not enabled.
