Microvellum Foundation Library Release Notes | Build 25.0813
The following release notes apply to the Microvellum Foundation Library build 25.0813.
Additions
  1. Added Metafile Rail Support Bracket as a hardware material, including associative machining tokens.
  1. Added the Richelieu Knock-In Assembly Fitting as a Hardware Array connector option.
  1. Added the Blum Tandem Rear Mount Brackets, including 3D images and associative machining.
    1. Added a selection option in the Drawers section of the Hardware Wizard.
    2. Updated all Wood Drawer Boxes and Pullouts with the selection options.
  1. Added Grass Base Mounted drawer slides.
  1. Added Base/Tall/Upper Pocket Doors products.
  1. Added the new Ladder product.
  1. Added the new Toe Kick Platform product.
  1. Added the new Hawa Concepta Pocket Doors product.
  1. Added global variable controls for “Drawer Bottom Max Span” and “File Drawer Bottom Max Span”.
  1. Added a new global variable, “Construction Method Scribe Filler with Cleats”.
  1. Added a new global variable, “Filler to Floor”.
    1. All Filler products and the subassembly “Filler to Floor” prompt have been updated to reference this new global.
    2. Added “Cleat to Floor” prompt in Scribe Filler with Cleats product and subassembly.
  1. Added drawing tokens to the Blum Space Step for the face to show in plan and elevation drawings.
  1. Added an Electric Cooktop option into the Countertop Appliance Options in the F Workbook.
  1. Added Fisher Paykel induction cooktops to the Electric Cooktop options.
  1. Added a control for Splay Edge Top Width to the Door Wizard.  Connected the Finished Faces and MV Profile Door subassembly prompts to new variable for higher level control.
  1. Added a prompt to the MV Profile Door "Face_5_Only_Trigger". If TRUE the machine point will change from a 4 to a 3M, and the glass and panel insert cutouts and rebates will be placed on face 5.
    1. This condition is triggered when the internal profile is 'None' or its route passes (Column 2 in the Door Wizard) equal 0, and the Edge Profile is 'None', and either Glass Door equals 1 or Panel Insert equals 1.
  2. Added the FGV Unilux drawer system.
  1. Added new Glass Shelf subassemblies, including new material pointers and the following added to the list of available inserts:
    1. Shelf Adj Glass
    2. Angled End Shelf Adj Glass
    3. Angled Shelf Adj Glass, Any Angled Shelf Adj Glass
    4. Diagonal Angled Shelf Adj Glass
    5. Shelf Adj Glass Angled Ends
    6. Corner Shelf Adj Glass
  1. Added four new CAD Templates (DWT) files for Toolbox BSB. *
    1. BSB Metric Annotative Drawing Template
    2. BSB Imperial Annotative Drawing Template
    3. BSB Extruded Product Builder Metric
    4. BSB Extruded Product Builder Imperial
  1. Updated the size and position of the Component Doors in the Tall 1 Door Double Door and Tall 2 Door Double Door products. Also resolved door hinge and bumper hardware locations.
  1. Resolved an issue Top and Bottom Valance not working in Full Inset Doors.
  1. Resolved an issue with top hinge location on Sink Cabinet products with vertical rails.
  1. Resolved an issue in the Diagonal Vertical Designer Cabinet when selecting 2 Door as a Face Option.
  1. Updated the Post Laminate subassembly.
    1. Updated the overall size of subassembly to account for options that extend the sides and back to the floor.
    2. Added additional prompt in subassembly to better control the size of the post laminate parts.
  1. Updated all Toe Kick Assembly Box subassemblies to follow the global "Construction Method Toe Kick".
  1. Resolved an issue with Cabinet Modification Options in the Upper Rangehood Cabinet. “Center Ducting Box” is now the default selection and shows up in the drop-down options.
  1. Resolved an issue with location of Vauth Sagel COR Wheel pullout in Base, Tall, and Upper Corner Cabinets.
  1. Resolved an issue with drilling on Full Applied Back in Tall Fridge Cabinet.
  1. Resolved an issue with Wine Rack Trellis X having missing parts.
  1. Updated the Corner Filler with Cleats products with additional prompts to control Left and Right Filler Widths.  Previously, there was on prompt, Filler Width, that controlled both sides.
  1. Resolved an issue with Shelf Adj drilling when "Continuous Shelf Holes" was selected.
  1. Updated the help text for Construction Method Left, Construction Method Right, Construction Method Top, and Construction Method Bottom for better clarity of the application.
  1. Resolved an issue with placement of Blum Aventos HF Top hardware.
  1. Updated Box End and Base Island Box End with the following:
    1. Left/Right Infill Panels – follow the Applied End Type selection
    2. Added 2D Elevation tokens to draw properly with the applied panel selections
    3. 2D Elevation width dimension token added.
    4. 2D Elevation height dimension tokens added.
  1. Resolved issues with Shelf Adj Angled Ends subassembly when shelf edge type is set to mitered:
    1. Adjusted the Z origin.
    2. Added miters to the ends so the edge aligns with shelf.
  1. Resolved issues with Shelf Adj and Shelf Fixed involving association with “G!UseMiterfold” turning on miterfold shelf part.  Updated to only turn on with “G!UseMiterfold” and “Shelf Edge Type” set to mitered.
  1. Resolved an issue with Applied End Type not drawing in 2D elevation when set to Generic Five Piece.
  1. Resolved an issue with 2 Door Microwave Upper Cabinet section drawing. The pull was not accounting for the Appliance Opening.
  1. Updated the grain marker block to rotate properly on Solid Wood Door subassembly.
  1. Resolved the issue of Hawa Concepta III Doors missing doors with Door Type was set to MV Profile Door.
  1. Resolved an issue with Diagonal Angled Shelf Fixed being placed in the wrong location when construction method was not set to dado.
  1. Resolved an issue with Solid Wood Doors missing panels when adding mid stiles to door.
  1. Resolved the issue of 3 Door Cabinets not having equal doors when Double Mullion was selected.
  1. Resolved an issue with door/drawer front cutouts when Single Panel was selected for Face Frame Option.
  1. Resolved an issue in the MV Profile Door with No Profile Handle not following the Door Wizard selection.
  1. Updated the 2D Instructions subassembly to represent elevation correctly when Elevation Show Hidden Carcase Layers is checked on.
  1. Resolved issues with back heights for the Furnware Symetra drawer system.
  1. Updated Cabinet Chamfer Bottom, Cabinet Chamfer Top, and Cabinet Chamfer Top and Bottom subassemblies.  The angles and positions have been corrected.
  1. Updated the Range Hood Master product. Applied several corrections.
  1. The below products will now respond to selecting “Shadow Line” global variable to on:
    1. Master 2 Bay Vertical Cabinet
    2. Tall 1 Door Double Door
    3. Tall 2 Door Double Door
    4. Tall Pantry With Drawers
    5. Tall Wall Oven
    6. Tall Wall Oven Full Box
    7. Tall Wall Oven With Microwave
    8. Tall Wall Oven With Microwave Full Box
    9. Master Wall Oven Cabinet
  1. Added additional functionality to the Mid Rail Extension options to include bays with Top Drawer selected.
  1. Added Face Frame dimension token for the opening size in Blind Corner Cabinets.
*Not included in Library Update, only in the full install.
To download this build, visit the Microvellum Portal.
