Microvellum Foundation Library Release Notes | Build 25.1024
The following release notes apply to the Microvellum Foundation Library build 25.1024.
Additions
  1. Added Face Profile Options to the Door Wizard for enhanced design flexibility. Users can now apply decorative visual profiles to doors, drawer fronts, applied panels, and fascias. This feature uses the Carving Token which is added to the display decorative face profiles. Available Profiles:
    1. None
    2. Reeded (6.35mm – 1/4in)
    3. Reeded (12.7mm – 1/2in)
    4. Reeded (19.05mm – 3/7in)
    5. Cove (6.35mm – 1/4in)
    6. Cove (12.7mm – 1/2in)
    7. Cove (19.05mm – 3/4in)
  1. Added options for Double Top Drawer to the Master 2 Bay Horizontal Cabinet and the Master Horizontal Designer Cabinet.
  1. Added Front Bay Double Top Drawer and Rear Bay Double Top Drawer options to the Master Double Sided Cabinet.
  1. Added new Hettich Drawer Slides:
    1. Quadro 5D V6
    2. Quadro 5D
    3. Quadro 25D
    4. KA 3320
  1. Added new Hettich Hinges with 45mm drilling pattern:
    1. Intermat
    2. Optimat
    3. Sensys
    4. Veosys
  1. Added Finista Edge Drawer System.
  1. Added Servo-Drive for Blum Aventos as an option in the LiftUp Doors.
  1. Added “Construction Method Thick Back FE” to the global and project wizard.  This will allow more control over construction methods.
  1. Added “Filler Align with Door Top Gap” global.  This will allow the user to choose whether the filler is flush to carcase top or aligns with the top of the door.
  1. Added “Extend Vertical Front Rail Amount” global. The amount added will be in addition to the already calculated width of the Vertical Front Rail in the Sink cabinets with False Fronts.
  1. Added new drawing tokens in the "Shelf Adj" and "Shelf Fixed" subassemblies that are used when the “Shelf Edge Type” is set to Face Mounted Lip Down, Face Mounted Lip Up, or Mitered. If either of these options are selected, the drawing token for the shelf turns off and the new token turns on.
  1. Added Mirrored version of button-fix fasteners to resolve issue with incorrect machining when the machining face is changed :
    1. Added button-fix type 1 flush Mirrored, button-fix type 1 metal Mirrored, button-fix type 1 bonded Mirrored.
    2. Updated the hardware machine tokens for button-fix type 1 flush, button-fix type 1 metal, button-fix type 1 bonded.
  1. Resolved an issue with Upper 2 Door Glass Door product where Door Stiles and routes for glass did not align properly.
  1. Resolved an issue with the Master Any Angle Cabinet, occurring when Shadow Line Finger Pull was enabled:
    1. The full top will now cut and draw correctly.
    2. The Shadow Line Rails will now be sized and placed correctly on the right side.
  1. Resolved an issue that occurred when “Cabinet Modification Options” and “Cabinet Void” were enabled simultaneously:
    1. Top, Bottoms, and Shelves are all machining correctly in this scenario.
  1. Resolved issues with the Hettich Multitech Drawer System.
    1. “Softclose Right” prompt was always on but is now set to be off by default.
    2. “Front Fixing Brackets” are now rotated and located correctly.
    3. "Inner Front Wood" part will now look to the drawer height and as well as the top and bottom overlays.
    4. "Wood Drawer Spacer" is now in the correct Z location.
  1. Resolved an issue wherein “Toe Kick Notch” was not turning off when “Inset Toe Kick” was set to 0.
  1. Resolved an issue with the Drawer Box List Report, wherein the incorrect Drawer Width would be displayed on the report.
  1. Resolved an issue with Harn Alunan T Drawer System.
    1. Size T Depth 270 right slide is now rotated correctly.
  1. Resolved an issue with Corner Filler with Cleats product.
  1. Associative machining (Screw, Dowel, Cams) applied to the width of the cleat parts now reference the relevant "G!Small Part Threshold” variables for correct machining.
  1. Resolved an issue with hardware machining on Fixed Panel when set to Full Inset.  The following hardware machining has been updated:
    1. Button-fix type 2 Fixed Panel
    2. Keku AS Ush-In Fitting Fixed Panel
    3. Keku EH Suspension Fitting Left Fixed Panel
    4. Keku EH Suspension Fitting Right Fixed Panel
    5. Keku EHS Suspension Fitting Left Fixed Panel
    6. Keku EHS Suspension Fixing Right Fixed Panel
  1. Resolved issues with Master Double Sided Cabinet product:
    1. Applied Ends now size correctly when "Flush with Face" is on.
    2. The back being missing in product should be resolved.
    3. Push Catch hardware now rotates correctly when selected.
  1. Resolved an issue with the Wall component not placing the Tap Outlet in the correct location.  If “Tap Outlet 1 From Right Side” is selected, it will be placed at correct location from right.
  1. Resolved an issue with the “Fridge” subassembly and the Fridge appliance product.
    1. When selecting both “Appliance Panel” and “Add Handles”, the handles will now be located correctly on the panel.
  1. Resolved an issue with the Bracket Single product. The bracket will now be drawn in the correct Z location.
  1. Resolved a name error issue in the global “Default Waste Bin Pullout.”  This now correctly looks to the Hardware Wizard.
    1. NOTE: This will overwrite the existing value for this global.
  1. Resolved an issue with the face machining for the Rev A Shelf 5349 Waste Bin.  The face machining now aligns with the specifications and the 3D Graphics.
  1. Resolved issue with “Drawer Qty” not passing through to the subassemblies in the Master Split Height Designer Cabinet.
  1. Resolved an issue that would occur in Front and Rear Undermount Notch sizes when using Hettich Undermount Drawer Slides.
  1. Resolved an issue with the Master Split Corner Cabinet with Thick Back selected. The product will now turn off the middle back when Split Qty is set to a value of 2.
  1. Resolved an issue with Hinge Plates, wherein Liftup Doors and Drop Down Doors would move to the outside face of the top and bottom when the Top/Bottom Reveal values were increased. The hinge plates now stay correct located on the inside face of top and bottom.
  1. Resolved an issue with the Tall Fridge Cabinet when selecting Liftup Door as the Face Option and adding a value to the “Valance Height Bottom” prompt.  The door now sizes and locates correctly.
  1. Resolved an issue wherein the Electric Cooktop appliance was not placed correctly in Countertop products. The default value of the "Appliance Distance from Left" prompt now has the appliance centered.
  1. Resolved an issue with incorrect routing on Any Angle Cabinet when Inset Door Sides or Full Inset was selected.
  1. Resolved an issue with Corner Diagonal Cabinets and hinge plate location when Right Swing or "Two Door" was selected in Face Options. The right hinge plate now associates and is placed correctly on the right side.
  1. Resolved an issue with Wall product when Door and/or Window qty was changed to 3 or 4 and the wall was not showing the cutout for these. All Door and Window cutouts now appear in wall with all quantity selections. *
  1. Resolved the hardware association issue when Lockdowel E3259BM Channel Lock is selected in the Hardware Wizard as the Hardware Edge Array hardware. The incorrect edge offset was updated in the Look Up Table.
  1. Changed layer colors in all dwt drawing templates to be index instead of true colors. *
  1. Resolved a machining issue with the Extruded Base Cabinet. The dado notch in the top has been corrected.
  1. Resolved a machining issue with the Extruded Die Wall products. Shortened the dado on the bottom plate when using a toe kick to prevent the rout from hitting other parts in a nest.
  1. Renamed the BLUM CLIP top 95deg Knock_In hinges to Knock-In for consistency in naming convention.
  1. Removed prompts and machine tokens related to Saw machining from the Thick Panel subassembly.
  1. Updated the three Extruded Molding products – Extruded Base, Extruded Crown, Extruded Valance. Products have been refactored to match other extruded products in the library.
  1. Updated the Hardware Array machine tokens in the Wood Drawer Box subassembly so that it places the hardware correctly and references “H!LookUpTableEdgeArray” column 9 to determine if a single hardware item is required or not.
  1. Updates were applied to the Blum REVEGO Pocket Doors product.
    1. Fixed multiple bugs of component sizing & location.
    2. Hardware & machining has been updated to reflect Blum's forthcoming release.
    3. Updated help texts & images to make cross referencing Blum's documentation clearer.
    4. Countertop height options have been added.
    5. Updated the baseline of REVEGO hardware 3D graphics.
  1. Resolved an issue with the Finished End 2D drawing text not turning off with global or prompt controls.
  1. Resolved an issue with the Face Frame Base and Upper Split Height Cabinets.  The face frame elevation will now draw correctly with or without “Show 2D Elv Face Frame Parts” selected.
  1. Resolved an issue in Diagonal Corner Cabinet FF products with the top and bottom front angle when Width and Depth are not equal.
  1. Resolved issues with 2D Elevation representations in FF products.
    1. When adding a value to Extend Bottom Rail Down Amount this will not show correctly in elevation.
    2. When selecting Face Frame as the “Left/Right End Condition” will not show the inset panel in elevation.
    3. When selecting Applied End as the “Left/Right End Condition” will no longer show the thickness of the applied panel or the dimension of the thickness in elevation.
    4. Resolved issue where stile/rail joint lines were still showing in elevation when stile was turned off.
  1. Resolved issue with parts not drawing in the Master/Base/Tall/Upper Open Corner End Cabinet FF products.
Items marked with * are not included in Library Update, only in the full install.
To download this build, visit the Microvellum Portal.
