Microvellum Foundation Library Release Notes | Build 25.1121
The following release notes apply to the Microvellum Foundation Library build 25.1121.
Additions
  1. Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category.
  1. Added the Nesting Optimization Report Select Processing report to the list of available reports.
  1. Added 2D elevation representation for Crown and Base Moldings.
    1. Added an additional column, 2D Profile Lines, to the Molding table and input line locations for existing moldings.
    2. Created Left and Right End blocks for each existing molding for return representation.
  1. Added new Master Split Blind Corner Cabinet product.
  1. Added “Top/Bottom/Both” option for "Push Catch" in the MV Door, MV Profile Door, and the Solid Wood Door subassemblies. This will default to “Bottom” in base cabinets when Vertical rail is selected. This was causing an issue with the catch rotating.
  1. Added option to have center legs in Corner Adj Leg subassembly. Additionally:
    1. If “Width” or “Depth” is greater than “Width to Add Center Legs”, center legs will be added to the backs.
    2. If the “Pie Cut Distance Left/Right” is greater than “Width to Add Center Legs”, center legs will be added at the front.
  1. Added the new Extruded Soffit product. This is a rules-based parametric extruded product.
  1. Added the Hettich Slimline M sliding door hardware to the Component Sliding Door subassembly. Includes all 3 track options for inset doors, Press In, Screw On, and Glue On.
  1. Added the Richelieu 908 and Richelieu Optimiz-R Drawer Kits to the hardware file. These additions match the subassemblies and graphics that were already available. Pricing can now be added to these kits at the Library level, if needed.
  1. Updated the “Left/Right End Dimension” prompt in all products. These prompts will now read the “G! Finished End Dimensions” variable and the product’s “Left/Right Finished End” prompt before turning on the drawing token.
  1. Modified standard DWT files:
    1. Updated the settings for both Hidden and Conceptual visual styles so that it appears and plots correctly in Paper Space.
    2. Updated the Layout Tabs to open zoomed to extents.
  1. Modified the Drawer Division subassembly “Double Division” prompt. This will now grey out if the prompt is present in the product prompts.
  1. Modified the Component Doors subassembly “Symmetrical Door” prompt. This will now grey out if the prompt is present in the product prompts.
  1. Resolved an issue with the Drawer Division height not calculating correctly when “Drawer Stretcher Offset” value was changed.
  1. Resolved an issue with top and bottom plates of the Die Wall w Studs product occurring when the “Bulge” calculation was “-“.
  1. Resolved an issue with Extruded Part Vertical product’s “Height” prompt. It now has the UCN formula to work in both metric and imperial correctly.
  1. Modified the “Mounting Position” prompt in the Kessenbohmer Wastebin Pullout subassembly to grey out if that is not an option for the Waste bin model selected.
  1. Resolved an issue with the Nikol Teramo Bin subassembly where the side drilling was incorrect.
  1. Resolved an issue with the right-side slide drilling in the Blum LEGRABOX subassembly. It will now drill through on the right side if there is a division, if selected.
  1. Added the Illumination design element to the Hettich AvanTech YOU drawer system.
  1. Updated the names for the Rev-A-Shelf 5349 Bottom Mount Waste Bin hardware items and drawing names. They now say “Waste” instead of “Waist”.
  1. Resolved a pair of issues in the Wall room component product:*
    1. Dimensions will now appear for Window 2 when "Dimension Openings" is checked.
    2. Outlets 1-4 Type will now appear correctly in 3D and 2D plan and be spaced apart by default instead of having the same distance for all.
      1. Note: This will need to be manually added, if updating.
  1. Resolved an issue with 2D plan drawings of the Extruded Master Countertop when using the Butt Join option for "Left/Right Join Type" prompts.
  1. Resolved issues with the “Strip Lighting Left/Right Distance” from “Top” prompts value in the Strip Lighting Insert subassembly.
  1. Resolved an issue where selecting “Panel Insert” on a right-swing MV Profile Door caused the panel to be positioned incorrectly. The panel now inserts in the correct location.
  1. Updated the construction method in Scribe Filler subassembly and products to look to the “Construction Method Scribe Filler with Cleats” global.
  1. Resolved issue with Intermediate Stile being offset when adding Double Drawer in Face Frame products.
  1. Resolved issue when adding Cabinet Modification and selecting “Cabinet Notch Left” or “Cabinet Notch Both sides”.
  1. Updated the Applied Panel subassembly drawing token for part thickness dimension in plan view. It now follows the global “Plan Width Base/Tall/Upper Point”. If the global is set to "None", the Applied Panel thickness dim in plan turns off.
  1. Resolved an issue within Master Split Cabinets wherein the nailer was not extending the full length needed.
  1. Resolved an issue with the “Shadow Rail” in the Tall Pantry product. This now works on drawers and has options for the “Vertical Shadow Rail” when a single door.
  1. Resolved an issue in the Finista drawer system. The runner holes and back fixing bracket machining now drill in the correct locations.
  1. Resolved an issue with the Master Upper Split Height Cabinet FF where the sides would not draw in model.
  1. Updated Face Frame Rail Modifiers to work when Face Frame Option is set to “Single Panel”.
  1. Added the “Intermediate Drawer Stile” option to Drawer Division FF subassembly.
  1. Added global “Face Frame Top Scribe Amount”, as well as the “Extend Left/Right Stile Up Amount”, “Extend Top Rail Up Amount”, “Top Scribe Amount” prompts to the Face Frame subassemblies.
    1. Top Rail and Stiles will extend up the “G! Face Frame Top Scribe Amount” on Tall and Upper products. This can be controlled at the subassembly prompt level for individual cabinets.
Special Note:
  1. The “Unitless Decorative Laminate” Specification Group has been removed from the library as well as the Formula Cutparts and Edgeband component files. Most of the associated formula materials have also been removed to make way for a new soon to be released group of formula materials in beta at the time of this release.
Items marked with * are not included in Library Update, only in the full install.
To download this build, visit the Microvellum Portal.
