Microvellum Foundation Library Release Notes | Build 26.0430
The following release notes apply to the Microvellum Foundation Library, build 26.0430.
Additions
  • Added new options to Add Interior Label for cross section, plan section, and elevation section. New Global Variables include:
    • “Add Interior Label Cross Sect”
    • “Add Interior Label Plan Sect”
    • “Add Interior Label Elevation Sect”
    • “Finish Label Options Interior” (Select from Material Comments or new Wizard Variable.)
    • “Finish Label Interior From Top”
    • “Finish Label Interior From Back”
  • New Project Wizard Variables include (Located on new Interior Finish Labels tab):
    • “Interior Finish Label Base”
    • “Interior Finish Label Tall”
    • “Interior Finish Label Upper”
  • Updated 2D Instructions, 2D Instructions Corner, and Angled Ends 2D Instructions subassemblies with new prompts:
    • “Finish Label Interior”
  • Updated the 2D Instructions, 2D Instructions Corner, and Angled Ends 2D Instructions subassemblies with new tabs, including:
    • Plan View
    • Elevation View
    • Section View
  • Added the option to control interior hinge overlays in the Component Doors FF using 2 new prompts, “Door Overlay Hinge Left” and “Door Overlay Hinge Right”, only visible when Face Options is set to "Two Doors".
  • Added new Edgeband categories, including PVC, ABS, and Misc to better organize the edgebanding materials.
  • Added a new global variable “Upper Top Nailer Width”. This has been linked to a new local variable present in Upper cabinets to allow the top Nailer width to be different than the other Nailers.
  • Added a new table to the Hardware (H) workbook, “LookUpTableShelfClip”. This can be used to manage all shelf support clips. When changing between the different clips, will automatically set the correct gaps and drillings. Includes columns for regular shelf clips and fixing shelf support for drill and slot installation in addition to Shelf Standard
  • Added additional shelf supports to the Hardware library:
    • Futaba Shelf Support
    • Richelieu Metal Shelf Support
    • Hafele Fixing Plug Shelf Support
    • KV 256
  • Added the Diagnostic Machine Token Test Product to the Miscellaneous This product is useful for testing Microvellum machine/drawing tokens.
  • Resolved an issue with Overlay Bottom receiving machining when Bottom Return on filler is selected.
  • Resolved an issue with Angled Ends Toe Kick Assembly Box not aligning with the cabinet sides of the Master Angled Ends Cabinet product when Toe Kick Assembly is changed to Toe Kick Assembly Box.
  • Moved the “Pelmet Stretch” and “Pelmet Width” prompts to the Legacy tab in Globals.
  • Updated the Cost Based Estimating Report - Shop Quote Optimized Option report to show correct Material Name in the Optimized Sheet Stock Cost category when multiple sheet sizes for the same material are being used.
  • Updated the Hawa Concepta III:
    • Corrected the “T1 Left/Right” references in the lengths of parts to look to the correct variable.
    • Added warning message to show when “T1 Left/Right” – “Left/Right Door Protrusion” > depth of the subassembly.
  • Resolved an issue with Drawer Front sizes and location when there are 2 Top Drawers and the Horizontal Gap was changed. Drawer Fronts now size and locate correctly.
  • Resolved issues with the Tall Fridge Cabinet FF:
    • Resolved an issue with Applied Panel FF where the “Right Applied End” prompt was always on and set to a static 1.
    • Removed the reference to “Finished Ends” and “Applied Ends” from the length of the left and right sides and added that logic to the “Extend Left/Right Side to Floor”. This automatically resolved the issue with the notch on the side when not extended to floor.
    • Added “Extend Left/Right Applied End to Floor” prompts to the Construction Options. The default is now looking to the “G!Applied Ends To Floor”.
    • Applied Panel FF - Added “Applied Ends to Floor”.
    • Added Prompt Value to Applied Panel FF subassemblies to pass through to “Applied Ends to Floor” when "Extend Left/Right Applied End to Floor" is selected. The value looks to “G!Applied Ends To Floor” by default.
    • The formula for "Face Frame Right Side Overlay Control" was incorrectly referencing Left Finished End, which was also affecting many other face frame products. This has been corrected.
  • Resolved issues with the Tall Fridge Cabinet:
    • Adjusted width of the Fridge subassembly when “Left/Right Side Full Height” is selected to avoid overlap of part and fridge block.
    • Added the Toe Kick options for cabinet side. Limited to “None” and “Notched Toe Kick”.
    • Added the same toe kick controls that are consistent with other products.
  • Resolved an issue with Master Double Sided Cabinet where parts were not drawing or located properly.
    • Updated the “Vertical Profile Left/Right Side” to reference Front Bay Face Options instead of Face Options, which doesn't exist in the product.
    • Changed the Rear X Origin formula to include the “Applied End Thickness Left” variable when vertical shadow line options are selected.
    • Updated the left and right sides “Width” and Y Origin to properly size and locate when vertical shadow line options are selected.
    • Updated the Rear Shadow Rail subassembly to match the Shadow Rail subassembly with the “Vertical Rails X” location adjusted to be properly located.
  • Resolved an issue with the DTC Smooth drawer system where the Rear Fixing bracket was not located properly. Updated the drawing names for the High Pot Rear and Interior Fixing Brackets.
  • Resolved an issue with Division FF occurring when using dado attachment method.
  • Resolved an issue with Extruded Diewalls when using multiple Inside Skin qty with a gap between. Inside Skins now work as Outside Skins.
  • Resolved an issue with shelf material when using Divisions With Adj Shelves and Divisions With Fixed Shelves where the material prompts were still looking to the Wide Span pointers.
    • Added new local prompt “Use Wide Span Shelf”.
Items marked with * are not included in Library Update, only in the full install.
To download this build, visit the Microvellum Portal.
