Microvellum Foundation Library Release Notes | Build 26.0527
The following release notes apply to the Microvellum Foundation Library build 26.0527.
Additions
  • Added new features for the Wood Drawer Box to have reduced sides, sub front, or back. Added 3 new global and subassembly prompts:
    • “Wood Drawer Side Reduction”
    • “Wood Drawer Sub Front Reduction”
    • “Wood Drawer Back Reduction”
  • Added the “L! Use Wide Span Shelf” to the Material Options tab in standard products. This is a multi-purpose addition, giving a user more control over shelf materials at product level and resolving an issue with Wide Span Shelf material being assigned to bays that do not meet the requirements for the Wide Span setting.
  • Added Appliance Options to all countertop products in both the Countertops and Extruded Countertops categories for better consistency between similar products. The one exception is the curved extruded countertop.
  • Added a new Product Prompt to most standard products, “Use Wide Span Shelf”. Users now have better control over the shelf material thickness at the product level for all shelves in the product. For differences in shelf material within a single product, the material would be changed at the subassembly level.
  • Added render material assignments to all sheet stock, solid stock, buyout, and edge band materials. * See the following article for more information.
  • Resolved an issue with Blum REVEGO Pocket Doors product where the Door Stabilizer machining wasn't working when using Uno Right as the Product Selection.
  • Resolved an issue with Master Curved Front Cabinet Finished Face quantity calculation.
  • Resolved an issue with Divisions, Division with Adj Shelves, and Division with Fixed Shelves when Through Dado Bottom was selected where the dado lead in and out were not calculating correctly and leaving a large gap.
  • Updated the DRAWDIM tokens for Cross Sections so all vertical dimensions align. Subassemblies updated:
    • 2D Instructions
    • 2D Instructions Corner
    • 2D Angled End Instructions
    • Finished Faces
    • MV Profile Door
    • Solid Wood Door
  • Resolved issues in the Shelf Adj and Shelf Adj Glass wherein shelf pin drilling was not showing when Cabinet Modifications Notch Left/Right/Both Sides was selected and Back and Side Thicknesses were different.
  • Updated the Flatshot Instructions subassembly so that “Front Elevation” text location is consistent in all product types.
  • Resolved an issue with the Shelf Adj and Shelf Fixed where the PLINE tokens for Cabinet Modifications were not working due to Name Filter not including the “Bay Position” in the name.
  • Resolved an issue with Horizontal Splitter where the PLINE token for “Cabinet Notch Top/Bottom” was not working due to incorrect X and Z vector locations.
  • Resolved an issue with Adj/Fixed Shelf Material incorrectly looking to Wide Span pointers when Internal Insert was changed to Divisions With Adj/Fixed Shelves.
  • Resolved an issue with “G!<Product Type> No Bottom” variables not being changeable due to the control type. There is now an option to change all three product types at a global level.*
  • Resolved an issue with the misspelled global variable, “Defalt Inner Wood Drawer Slide”. This has been corrected to “Default Inner Wood Drawer Slide”. *Update Note: After running update, confirm your selection. The value formula did not change nor did the H! variable.
  • Resolved an issue with Shadow Rail selection not applying the correct Shadow Rail subassembly name when there were more than one Shadow Rail in a product. All Shadow Rail subassemblies in a product will not look to the same “G!Shadow Rail Name” variable. This issue was also resolved in the Component Drawers and Component Door Drawer subassemblies.
Items marked with * are not included in Library Update, only in the full install.
To download this build, visit the Microvellum Portal.
