Added new global variable “Post Laminate Faces”. Previously, when using Post Laminate on Finished cabinet parts (but not doors), users had to change the Finished Faces subassembly or its prompts each time to prevent doors from using post laminate. This new variable solves that issue.
Resolved issue when “Valance Height Bottom” value was greater than 0. Previously, the cabinet bottom and sides were not adjusting when "Valance Height Bottom" >0.
Updated formula: =IF(AND(Add_Under_panel=1,Under_Panel_Include_In_Height=1,Valance_Height_Bottom>0),Valance_Height_Bottom,IF(AND(Add_Under_panel=1,Under_Panel_Include_In_Height=1),Under_Panel_Edge_Width,Valance_Height_Bottom))
Resolved an issue with the continuous holes setting not passing through to the shelf when it was a nested subassembly. Continuous holes value were specifically not passing through to Nested Shelf Adj.
Resolved an issue with Toe Kick Assembly Box parts showing machining from carcase parts. This issue appeared when processing, as parts would be blocked from flipping during optimization, which created a secondary operation. A hidden prompt has been added to the Toe Kick Assembly Box, “Height Offset”.
Resolved an issue with Drawer Division protruding below drawer fronts. Division(s) in 2 Drawer Suspended Cabinet were incorrectly sized when “No Bottom” is selected. The Division(s) protrude below product by “Dado Depth” value.
Resolved an issue with missing notch on Drawer Divisions when Shadow Line Finger Pull is selected. The PLINE virtual route had an incorrect formula format, which resulted in route not being activated. The formula is now fixed, which should eliminate manual machining process for shadow line rail notch.
Resolved an issue with the “Door Gap” prompt not having a visible control type in all corner cabinets. The control type for the “Door Gap” prompt has been changed in the Base/Master/Tall/Upper Corner Cabinet FF products.
Resolved an issue with occurring in the Wood Drawer Box when construction method was set to Hardware Array. When using the Cabinet Notch Center cabinet modification with Hardware Array as the construction method, the logic for the left and right Drawer Backs would mismatch. The formula for EDGEARRAY3 and 4 have been changed to prevent this issue.
Resolved a hardware reporting issue with the Bracket Single and Bracket Array products. Bracket Qty was reporting brackets twice, once in the product and once in the subassembly. Product level hardware has been removed from both, resolving the issue.
