The following release notes apply to Microvellum Foundation Library build 26.1030.
An issue that placed a lock on both doors of pie-cut corner cabinets when "Add Lock" was enabled has been resolved. The lock is now only placed on the opening door, as a prompt value on the hinged-door side turns off "Locked Door" in the subassembly. Products updated include:
- Base Corner Cabinet
- Base Corner Diagonal Cabinet
- Master Corner Cabinet
- Master Split Corner Cabinet
- Tall Corner Cabinet
- Tall Corner Diagonal Cabinet
- Tall Corner Pantry Cabinet
- Tall Corner Split Pantry Cabinet
- Upper Corner Cabinet
- Upper Corner Diagonal Cabinet
- Base Corner Cabinet FF
- Master Corner Cabinet FF
- Tall Corner Cabinet FF
- Upper Corner Cabinet FF
- Resolved an issue where the "Add Vertical Rail" prompt appeared on corner cabinets where it does not apply, such as Upper Corner Cabinets with Full Top enabled and open corner cabinets. The prompt now only appears on Base corner cabinets and has been hidden in the Face Frame corner cabinets.
Issues within the Division with Fixed Shelves subassembly have been resolved, including:
- Shelf construction settings not following changes made to the Left/Right construction methods on the parent subassembly. The Shelf Fixed construction method prompts now take their values from the parent subassembly.
- The right shelf not being set correctly in relation to the division. The right shelf prompt value now correctly sets "Is Division Left".
Front Protrusion and Nominal Length lookup issues have been resolved with the Blum REVEGO Pocket Doors, including:
- Front Protrusion values reading negative or matching on both sides and ignoring "Override Nominal Length". Left and Right pockets now report their own protrusion.
- Nominal Length lookups failing when the pocket depth was exactly 500, 600, 700, 750, or 800mm, which caused drawing errors and missing machining.
The Blum REVEGO Pocket Door system has been verified with Blum, and the following issues have been resolved:
- Hardware errors when using the Front Width Calculator with unequal door widths. The "Left_Door_Width" and "Right_Door_Width" prompts now read the correct Front Width values.
- The Track Connector disassociating when Uno+Duo was selected in Imperial.
- Scuff guards being positioned incorrectly in Imperial.
- Incorrect finished parts, layers, and edgebanding on the inner pocket sides.
Issues with the Grass Z Box file drawer have been resolved, including:
- File rails not displaying when used as a file drawer. The file rail logic has been rebuilt for the 6100, US, Aluminum, and 6110 file systems, and file hardware, front and back drilling, and Grass back heights have been added.
- The drawer breaking after the "Drawer Height" prompt was changed. All Drawer Height lookups have been updated to prevent this.
