Microvellum Foundation Library Release Notes | Build 21.0201
The following release notes apply to Microvellum Foundation Library, Build 21.0201
Additions:
  1. Added Toe Kick Base product.
  2. Added Angled Toe Kick Base.
  3. Added Scribe Filler product.
  4. Added Scribe Filler with Cleats product.
  5. Added Return Filler product.
  6. Added Corner Filler with Cleats product.
  7. Added Grass Vionaro Drawer System.
  8. Added Cabinet Wall Hangers subassembly for standard and corner cabinets.
  9. Added Hettich Intermat Hinge Range.
  10. Added Hettich Sensys Hinge Range.
  11. Added Grass Tiomos Hinge Range.
  12. Added Grass Nexis Hinge Range.
  13. Added drawer stretches to master cabinets.
  14. Added drawer stretches to the component drawer’s subassembly.
  15. Added “Drawer Type” prompt to Master Horizontal Designer Cabinet.
  16. Added “Drawer Slide Selection” prompt to Master Horizontal Designer Cabinet.
  17. Added Inset division prompt to Master Horizontal Designer Cabinet. This provides the option for bay divisions to be behind or flush with the doors and drawers when selecting “Full Inset Doors”.
  18. Added “Inset Fixed Shelves” prompt to Master Vertical Designer Cabinet. This provides the option for fixed shelves that divide the bays to be behind, or flush with, the doors and drawers when selecting “Full Inset Doors”.
  19. Added Brand selection for hinges and hinge plates in the hardware wizard.
  20. Added Drawer Stretcher prompt to the Global File.
  21. Added Drawer Stretcher Inset prompt to the Global File.
  22. Added Drawer Stretcher Offset prompt to the Global File.
Modifications:
  1. Modified Face options Bay 2 list to exclude drawers. This option is not available for the top bay.
Resoluti​ons:
  1. Resolved name error issue in the “Drawer Handle Type” prompts control type for the Master Horizontal Designer Cabinet.
  2. Resolved issue with the Component Drawers Subassembly prompts “Drawer type” And “Drawer Slide Selection” not looking at the local product.
  3. Resolved issue with a name error in the height of the shadow Rail nested subassemblies in the Component Drawers Subassembly.
  4. Resolved issue when selecting inset doors in the Master Horizontal Designer Cabinet. The doors and drawers would not inset at the top and bottom.
  5. Resolved issue with Shadow line virtual routes on the right-hand side machining incorrectly.
  6. Resolved imperial/metric value issue with the door bumpers.
  7. Resolved issue with the right filler being placed in the wrong position in the Master Any Angled Cabinet.
  8. Resolved an issue with the fillers being in the wrong position and rotation in the Master Diagonal Angle Cabinet.
  9. Resolved an issue with the fillers being in the wrong position in the Master Transition Angle Cabinet.
  10. Resolved an issue with the division insert subassembly, when selecting “Add_Center_Shelf”. The top machining was incorrectly when attaching to the shelf.
  11. Resolved an issue with the Cross-Section drawings coming up with an error MVSOLIDWOOD.pat not existing.
  12. Resolved issue with the top and bottom chamfer cabinet modification subassemblies. The mortice on the left of the top and bottom were machining incorrectly.
View Release Notes from the Previous Build
