Microvellum build 26.1.1116, released on , includes changes to Microvellum BSB (BricsCAD), Microvellum AC (AutoCAD) and Processing Center.
Before you upgrade, read the Upgrade notes at the end of this document. They describe two changes you might notice right after upgrading.
Redraw Products can redraw every product in a project in one run, so you don't have to open each room and redraw its products one by one. It's designed for projects imported from other systems, which often arrive with all their products in the database and nothing drawn.
Click Redraw Products on the Microvellum palette, and under What To Redraw choose Selected Products, All Products in the Active Drawing or All Products in the Project. For All Products in the Project, Microvellum opens, redraws, saves and closes each room drawing, and it creates a drawing from your template for any room that doesn't have one yet. A progress bar shows each room as it's drawn, and Cancel stops the run after the current room. When the run finishes, a summary lists any room that had a problem. Rooms whose drawings are open on another computer or opened read-only are skipped.
To redraw the whole project without opening the Redraw Products window, type MVREDRAWPROJECT. If you use the Grid project viewer, the Rooms window also has a Redraw column for choosing individual rooms. Redraw rebuilds each product from the database, so any changes made directly to the drawn products are overwritten. Learn more
Draw Selected Product(s) in New Drawing puts each selected product in its own drawing file. It's on the right-click menu in both the Product List and the Product Viewer.
Two commands do the same for every product in a room or project, so you don't have to select the products yourself. Type MVDRAWROOMPRODUCTSINNEWDRAWINGS for the current room or MVDRAWPROJECTPRODUCTSINNEWDRAWINGS for every room in the project. If a product already has its own drawing, Microvellum asks before replacing it. Your room drawings aren't changed.
ReNumber Products can renumber every product in a room drawing at once, so you don't have to click each product in order, where one missed click can throw off the sequence.
Open the room drawing, and on the palette's Modify tab, click ReNumber Products. Enter the first item number, then choose All Products at the Enter renumber mode prompt. That mode is remembered for next time. Microvellum numbers the products wall by wall, in alphabetical order by wall name. On each wall it works from the bottom row up and from left to right as the elevation reads. Islands and other products that aren't on a wall are numbered last. Before anything is saved, a confirmation shows how many products will change and the range of numbers they'll get. Undo doesn't reverse a renumber, so check the confirmation before you click Yes. Learn more
Clash Detection finds parts that overlap in your drawing, so you can fix them before anything is cut. Overlaps are easy to miss because the drawing and the parts list can both look right until the product won't go together.
To run it, type MVDETECTCLASHING. On the Microvellum Clash Detection palette, choose Entire drawing or Parts I pick, then click Scan. Each result lists the product, the two parts and how far they overlap, and clicking a result zooms to the clash with both parts highlighted. The check looks at parts after machining, so a shelf that sits in its dado isn't reported, but a shelf pushed into a side panel with no dado is.
Options on the palette let you compare parts across neighboring products, include hardware, report parts whose faces touch, and set a minimum penetration depth. The scan doesn't change your drawing. Clash Detection has no button by default, but you can add the Detect Clashing command to your toolbar in Customize Commands. Learn more
Library Designer has a search box above the tree. Type part of a name and the tree narrows to the matching items and the categories they're in, so you don't need to know where an item lives to find it. To go straight to an item listed in Parts Using This Item, Products Using This Item or Subassemblies Using This Item, double-click its row, or right-click the row and choose Locate in Tree.
Click Export to Excel to save all three Using This Item lists to one workbook, which makes it easier to review or share everything a change will affect before you make it. Find and Replace also has an Export to Excel button for its results.
You can add or paste an item into every product in a category at once. Select a category, then click Add or Paste in the Parts, Prompts, Hardware, Subassemblies or Drawing Tokens group. A Choose Items list lets you leave products out before anything changes. If some products already have the item, a second Choose Items list lets you handle all of them at once: tick the ones that should get it anyway, as a unique copy or, for prompts, a replacement. Only products directly in the category are included, not those in its subcategories. Machine tokens can't be added this way.
Commit Changes and Find and Replace handle large jobs quickly, such as committing a few hundred changes at once or running a search that returns thousands of results. After a commit, the tree shows your changes right away, without closing and reopening Library Designer. Learn more
The Cathedral Grain setting keeps directional veneers grain-up when parts are nested. Without it, the optimizer can nest one part of a mirrored pair, such as the left and right ends of a cabinet, grain-up and the other grain-down.
To use it, edit a Sheet Stock, Solid Stock or Buy Out material in the Material File, set Grain to Length or Width, and select Cathedral Grain. Every part made from that material then nests grain-up. Cathedral Grain works on nesting stations that don't have Use Legacy Optimizer selected. On a station that has it selected, Microvellum shows a warning and nests those parts as standard grain. The setting doesn't affect saw optimization. Because these parts can't be rotated to fit, yield may drop slightly on some sheets. Learn more
You can generate a 3D model and a palette preview image for any product in your library. Most library products don't include a saved 3D drawing, and while the standard Microvellum library includes preview images, custom products created by users often do not. This lets you generate both, so it's easier to see what a product looks like before you add it to a drawing.
Right-click a product on the palette and choose Generate 3D Preview. Microvellum builds the model, uses it as the product's preview image, and opens it in a 3D viewer, where you can change the view and display style, then click Use as Preview to keep the angle you like. To create previews for a whole library, go to Options, select the Utilities tab, and choose Generate Product Previews. Previews are saved in your shared data folder, so everyone who uses that folder sees them.
Hardware has previews too. When you select a hardware item in the Material File, a preview of it appears, and View in 3D opens it in the same viewer. Learn more
Machining token filters can match part names by keyword. You limit which parts an associative machining token applies to by adding * and a list of part names to the token name. Libraries often name parts in families, such as Stud_Leg_1_#1_OL and Stud_Leg_1_#4_Brkt, and listing every exact name in a family is slow to set up and hard to keep current.
Put ~ in front of a name to match every part whose name contains that text. For example, CUTOUT*-Stud skips the part named Stud, and CUTOUT*-~Stud skips every part with "stud" in its name. Matching isn't case-sensitive, and you can mix exact and keyword entries in one list. Entries without ~ match the exact name, so existing libraries aren't affected. Learn more
The Microvellum palette's current room follows the drawing tab you're on, so the changes you save and redraw land in the right room drawing.
The Product Viewer reloads when you switch drawing tabs. If the drawing on screen isn't a room drawing in the open project, the current room label turns red, and the palette's Draw, Modify, Solid Modeling and Product Viewer tabs are unavailable until you switch to a room drawing or open the room. Save and Redraw from Product Prompts, Part Properties or Edit Design Data draws in the product's own room drawing and opens it if needed. You also can't switch drawings while products are being drawn. Learn more
Edit Multiple Product Prompts sets one prompt to the same value on many products at once. It offers only the prompts and values that fit every product you select, so you can't enter a choice a product doesn't offer or change a prompt the product locks, such as Width. You can open it from the Microvellum palette, with the MVPRODUCTPROMPTSMULTI command, or from Edit Product List > Edit Additional Prompts in the Product List.
Drop-down, check box and option button prompts give you a list of valid choices instead of a text box. Values you've loaded stay in place when you click in the prompt list, and the grid is easy to read in dark mode. Learn more
Rebuild Selected Products From Library replaces a product's parts list with the current library version. It's on the right-click menu in both the Product Viewer and the Product List. ReNumber is on both menus too.
Its confirmation message explains what happens to your prompts. Values you typed, including Width, Height and Depth, carry over, and prompts that use a formula take the library's formula. Materials, hardware and edgebands you picked from the material list in Prompts carry over too. Learn more
The Factory workbook is saved only when someone deliberately edits it, such as in Factory Variables, Workbook Designer or activity stations. Opening the Product List, switching between cost and price estimating, and processing a work order with Calculate Multipliers selected don't save it. One user's everyday work can't overwrite a change another user just made, so you don't have to wait until everyone is out of Microvellum to edit Factory Variables.
If two people edit Factory Variables at the same time, the last person to save overwrites the other person's changes.
Processing, Parts List Review, redraws, reports and Product List load specification group workbooks and other shared information once per run, rather than for each product. This cuts out repeated loading, which makes a noticeable difference on larger work orders.
mv_3ddxf post failed on any part with a saw cut, and it wrote saw depth as the height above the spoilboard rather than the depth into the part. Saw cuts are now written the same way as routes.Parts List Review doesn't create a hardware material when a product refers to hardware that isn't in the library. Microvellum creates that material the next time the product is drawn or processed.
If you turned off the Rebuild Selected Products From Library confirmation in an earlier version, it appears once more after you upgrade, because the message has changed.
