Microvellum build 26.1.1125, released on , is a small update for Microvellum BSB (BricsCAD) and Microvellum AC (AutoCAD). It adds a Clash Detection button to the palette and an option to check for clashes after a redraw. It also fixes a crash when drawing several products with a script, two problems with 3D product previews, and the Material File window changing its own height.
Clash Detection finds parts that overlap in your drawing. You can open it with the Clash Detection button on the Microvellum palette's Modify tab, as well as by typing MVDETECTCLASHING. After each scan, the Clash Detection palette shows how many clashes were found, or No clashes found, with the time of the scan, so you know the scan ran even when nothing turns up.
To check products as you work, turn on Check for Clashes After Redraw. You'll find it in the Product Prompts window, in the Drawing Style window and on the Clash Detection palette. All three share one setting, which is off by default.
While the setting is on, Microvellum checks products each time it draws or redraws them in 3D, and it reports only clashes that involve those products. If it finds any, the Clash Detection palette opens with the results. If it doesn't, the command line says no clashes were found. The setting doesn't apply when you redraw all products in the project.
This is the final build that supports the legacy post processor. Future builds will use the new post processor only.
We don't expect this change to affect anyone, as the legacy post processor is no longer in use to our knowledge. However, if your configuration was manually rolled back to the legacy post processor, a notice will appear when Microvellum starts.
If you see this notice, contact Microvellum Support for assistance transitioning to the new post processor. This update does not change your current post processor settings or machine code output.
