The following release notes apply to Microvellum build 25.2.0227.641
Processing Center Fixes
Multiple fixes and updates were applied to the standalone Processing Center application to improve usability.
Add New Configuration
- An update has been applied to enhance the compatibility between Processing Center and other Microvellum software products. The Processing Center is now able to detect configurations from other Microvellum products (such as AC and BSB) and allow users to utilize those configurations without issue.
Ribbon Fixes
- The ribbon in Processing Center is intended to display the “Show Patterns” option when the label type is set to Nest/Saw/Ardis. It was found that this was not the case, and the only option displayed would be “Print Labels”. This issue has been resolved- both options should now be displayed properly in the ribbon.
- The spacing of functions and buttons on the Processing Center ribbon has been adjusted to enhance the usability of the interface.
- The text coloration of many aspects of the interface in Processing Center has been adjusted improve text consistency.
Window Resize Fix
- When running Microvellum Production, it was noted that there was an issue with resizing the window of the Processing Center within the application. When minimizing and maximizing the window, it was sometimes the case that the bottom of the interface would be cut off, preventing specific features from being used.
