Microvellum Remote Desktop (RDP) and RDS Compatibility
Microvellum BSB and Microvellum AC support remote desktop connections to dedicated Windows computers, including physical workstations and persistent virtual desktops. However, Microvellum does not support multi-session environments, where multiple users run the software simultaneously on the same computer or server. The key requirement is simple: Only one Windows session can run Microvellum on a computer at a time.
This article explains which remote configurations are supported, why multi-session environments cause licensing problems, and what alternatives are available.
Compatibility by Configuration
Compatibility depends on how Microvellum is hosted and how Windows sessions are managed, not simply which remote access software is used.
Configuration
Supported
Notes
Remote Desktop (RDP) to a dedicated workstation
Yes
Microvellum runs on the workstation, with the user connecting remotely.
Dedicated, persistent virtual desktop
Yes
Each user has an assigned virtual machine with a stable identity.
Shared workstation used by different people at different times
Yes
Only one Windows session can run Microvellum at a time.
Non-persistent virtual desktop that resets between sessions
No
Resetting the desktop can remove or invalidate license activation information.
Windows Server Remote Desktop Session Host (RDS)
No
Multiple users share the same computer and licensing environment.
Windows 10/11 Enterprise multi-session, including Azure Virtual Desktop multi-session hosts
No
Multiple Windows sessions share one computer.
Remote access solutions such as RDP, Citrix, VMware Horizon, and TeamViewer can be used with dedicated workstations, provided the configuration meets Microvellum's requirements and the applicable CAD licensing terms.
For Microvellum to operate in a supported remote desktop environment, the following requirements must be met:
  • Dedicated Windows environment: Only one Windows session can run Microvellum on a computer at a time. Multiple users may access the same workstation at different times, but they must not run Microvellum in separate Windows sessions simultaneously.
  • Persistent computer identity: The computer or virtual machine must maintain a consistent identity. Changes to hardware identifiers, computer names, or virtual machine configurations may require reactivation.
  • Internet connectivity: Microvellum requires internet access for activation and periodic license verification. Floating licenses require an active connection to maintain their license sessions.
  • Supported hardware: Physical and virtual workstations must meet Microvellum's hardware and graphics requirements. See Recommended System Specs for Microvellum.
  • CAD licensing compatibility: BricsCAD and AutoCAD have their own licensing and virtualization requirements, which must also be satisfied.
Why Multi-Session Environments Are Not Supported
How Microvellum Licensing Works
Microvellum licenses are associated with the computer where the software is activated. Licensing information and session data are maintained at the machine level rather than independently for each Windows user.
This becomes a problem in multi-session environments, such as Windows Remote Desktop Session Host, where several users can run separate copies of Microvellum on the same computer.
Microvellum uses two primary licensing methods:
  • Single License Activation (SLA): Licenses are activated on specific computers and periodically verified with the license server.
  • Floating License Activation (FLA): Licenses are shared from a pool of available seats. When Microvellum starts, it establishes a license session that remains active while the software is running.
Licensing Conflicts with Multiple Windows Sessions
When multiple users run Microvellum on the same computer, they can interfere with one another's license information and active sessions.
With Single License Activation (SLA):
  • Multiple Windows sessions share the machine's activation information.
  • License changes, refreshes, or deactivations performed in one session can affect other users.
  • Activating additional licenses on the same machine does not provide independent licensing environments for each Windows session.
With Floating License Activation (FLA):
  • Multiple Windows sessions can share the same machine-level floating license session rather than establishing independent sessions for each user.
  • When one user closes Microvellum, the shared license session may be released, causing other users to lose their active license connection.
  • Multiple sessions accessing and updating the same licensing information can cause unexpected disconnections, licensing errors, and repeated prompts to restart a license session.
One common error associated with these conflicts is:
Your floating license session has ended due to an inability to connect to the internet or license server. Please check for issues with Internet or Firewall and then hit Retry or restart the program.
Although this message typically indicates a connectivity problem, it can also occur when another user's activity on a shared host disrupts the active license session.
Internet or firewall issues can produce the same message, so the error alone does not confirm that RDS is the cause.
Customers who want to access Microvellum from a hosted environment can use dedicated physical or virtual Windows workstations accessed through Remote Desktop.
In this configuration:
  • Each user has their own Windows workstation or persistent virtual machine.
  • Microvellum and its CAD platform are installed and activated on that computer.
  • Users connect remotely without sharing a Windows session host with other Microvellum users.
  • Each workstation maintains its own licensing information and resources.
This approach provides remote access to Microvellum without the licensing conflicts associated with multi-session RDS environments.
For businesses using cloud infrastructure, dedicated virtual desktops can provide a similar experience to traditional RDS environments while keeping each user's software installation separate.
Frequently Asked Questions
What's the difference between RDP and RDS?
  1. Remote Desktop Protocol (RDP) is the technology used to connect remotely to a Windows computer.
  2. Remote Desktop Services (RDS) is a collection of Windows Server technologies that can include multi-session hosting, where multiple users access applications on the same server.
  3. Microvellum supports standard remote desktop connections to dedicated workstations but does not support multi-session RDS hosting.
How do I know whether I'm using a multi-session environment?
  1. Ask your IT provider whether Microvellum runs on a dedicated workstation or on a shared Windows session host.
  2. You can also run query user in Command Prompt on the computer running Microvellum to view connected Windows sessions.
  3. Multiple sessions listed do not necessarily mean that multiple users are running Microvellum, but they may indicate a shared environment that needs further review.
Can two people use the same computer at different times?
  1. Yes. Multiple people can use Microvellum on the same computer at different times, provided only one Windows session is running Microvellum at a time.
We already have an RDS server. Can we install Microvellum on it?
  1. No. Microvellum BSB and AC are not compatible with Remote Desktop Services (RDS) environments that allow multiple users to run applications on the same server.
  2. If you need remote access to Microvellum, we recommend using dedicated Windows workstations or persistent virtual desktops accessed through standard Remote Desktop connections.
Does a floating license make RDS compatible?
  1. No. Floating licensing allows seats to be shared across different computers, but it does not provide independent license sessions for multiple Windows users operating on the same machine.
Can we run Microvellum on a cloud-hosted virtual machine?
  1. Yes, provided the virtual machine is dedicated, persistent, meets Microvellum's system requirements, and uses a supported Windows and CAD licensing configuration.
Need Help?
If you're planning a remote desktop or cloud-hosted Microvellum environment, we recommend reviewing your proposed configuration with Microvellum Support before making changes.
Our team can help clarify Microvellum's compatibility requirements so you can work with your IT provider to select an appropriate configuration.
