Supported Operating Systems
- Windows 10
- Windows 11
Processor (CPU)
- Minimum: Intel Core i5 or AMD Ryzen 5
- Recommended: Intel Core i7 / i9 or AMD Ryzen 7 / 9
Additional Notes:
- Prioritize high single-thread performance.
- More cores improve rendering and heavy multithreaded tasks.
- Workstation CPUs (Intel Xeon, AMD Threadripper) are best for large or complex projects.
Memory (RAM)
- Minimum: 16 GB
- Recommended: 32 GB or more
- Use multi-channel memory (at least one module per channel) for improved performance.
Storage
- Minimum: ~4 GB for Microvellum installation
- Recommended: SSD (SATA III or PCI-E NVMe) for system and software
- HDDs may be used for non-critical data storage
Display & Graphics
- Minimum: Full HD (1920×1080) True Color display with a graphics card that has 4 GB VRAM
- Recommended: Dual displays with a dedicated GPU that has 8 GB VRAM
Additional Notes:
- Mid-range gaming GPUs (NVIDIA GeForce, AMD Radeon) are recommended.
- Always install the latest drivers.
- For large models, parametric assemblies, or point clouds, enable High Performance graphics.
- CAD Platform Considerations
BricsCAD V25
- Uses the same hardware requirements listed above.
- Optimized for modern GPUs and multi-core CPUs.
AutoCAD (2024 /2025/2026)
- Minimum requirements are generally lower, but performance gains are noticeable with higher-end CPUs and GPUs.
- Autodesk recommends 16 GB RAM and 8 GB VRAM for 3D modeling.
- Network licensing may require additional configuration.
For the best experience with either platform, we recommend:
- Windows 11, Intel i7 or AMD Ryzen 7, 16 GB+ RAM, SSD hard drive, and an 8 GB+ GPU with dual displays.
