Overview: Library Build 048 - Door Data
The Door Data in the Microvellum Library v048 and greater has been significantly improved! The improved data is seen mainly in the solid wood panel doors, whereas the MDF and slab doors are relatively unchanged. This video gives a partial list of what has been improved with the new data.
The original solid wood door data was developed to provide a 3D representation of the doors. With the most recent data development, the data provides vastly improved cutlists and accurate machining, in addition to maintaining the original ability to provide a 3D representation of the doors.
As a reference for various properties of the new door data, we have attached a document named "Door Documentation 048 Library.pdf."
    • Tutorial: Library Build 048 - Door Data & Wizard
      This video explains the differences between the various type of door data (door libraries) contained within the Microvellum Library version 048 and where that data is located. You will see how the appearance of the prompts page adjusts based on the ...
    • Tutorial: Interacting with Door Data Prompts
      This video demonstrates how to maximize the default features of the Microvellum Library Solid Wood Doors. How to use the prompts and why various prompts are visible at different times. Also, how the dropdown list boxes are populated. How to use the ...
    • Tutorial: Using Haunched Solid Wood Doors
      This video explains and demonstrates how to use the new haunch feature of solid wood doors. How to activate haunch doors.  (begin – 00:44)
    • Overview & Tutorials: Using the Reduced Rail Feature of Solid Wood Drawer Fronts
      This video demonstrates how to use library data to adjust the drawer front heights when maintaining the same style and rail sizes as the door causes odd center panel sizes in the drawer front. Explanation of ‘reduced rail’ as it relates to drawer ...
    • Overview & Tutorials: Formula Generated Materials in Doors
      This video explains and demonstrates how to use formula generated materials in the default 048 library data. Prior to this library version, this had not been included in the shipping library data although some Users have been doing this in their ...
    • Toolbox Release Notes | Build 23.1.0329.641
      Toolbox Release Notes | Build 23.1.0329.641 Processing Center Resolutions: Resolved an error in the ‘View Nesting G-Code Results’ UI when trying to view DXF’s. ‘Modify Work Order’ will no longer remove certain edge band information if editing that ...
    • Microvellum Foundation Library Release Notes | Build 23.0320
      The following release notes apply to Microvellum Foundation Library, Build 23.0320. This update includes many changes & additions to the Microvellum Closet/Wardrobe Expansion. If you have not purchased this expansion, you will not have access to ...
    • Toolbox Release Notes | Build 23.1.0313.641
      Toolbox Release Notes | Build 23.1.0313.641 Label Images Resolutions: Resolved an issue with PTP stations not flipping the face 6 WMF image correctly. WMF orientation should now match the gcode. Resolved an issue with Unified Work Order databases not ...
    • Toolbox Release Notes | Build 23.1.0222.641
      The following Release Notes apply to Toolbox Build 23.1.0222.641. Machine Tokens Resolutions: We fixed a bug affecting certain libraries that used the CONST token, which led to incorrect calculations of the distance between holes. We also fixed an ...
    • Microvellum Foundation Library Release Notes | Build 23.0210
      The following release notes apply to Microvellum Foundation Library, Build 23.0210. Additions: • Added a new global variable “Hinge Offset From Edge” to provide easier control without needing to update the finished faces subassembly. • Added a sample ...
