Compatibility: Paperless Shop Floor Reporting works in Microvellum AC and in Microvellum BSB. In Microvellum BSB, use ARGDrawProd_BSB.scr, the BricsCAD version of the script included in the package, and build 26.1.1125 or later if you want to draw several products at once. On earlier BSB builds, draw one product at a time. This feature does not require DWF files.Download the "Paperless Shop Floor Reporting.zip" file attached below. The package holds a script file for each platform (ARGDrawProd.scr for Microvellum AC and ARGDrawProd_BSB.scr for Microvellum BSB), drawing templates in Metric and Imperial, an .sdf file with the reports a paperless workstation needs and the default report groups, and a setup document. Import the .sdf file with the Database Management utility.
Create a Shared Network Path where the reports will be stored, so everyone who needs them can get to them. Use a network location, a shared drive, or anywhere else that suits how your shop views its manufacturing data.
On the palette, choose Microvellum Settings, hover over Design Reports, then Setup Report Groups. A report group is a set of reports and labels that Microvellum generates when it processes a work order. You can set each group's output location, extensions and name modifiers to suit your production needs.
Open the default report group "HTML" and set its Output Location to your Shared Network Path. Do the same for the default report group "Work Order List", and make sure no report has an alternate destination.
Open the report settings for the HTML and PDF exports and set them to your preferences. We recommend the settings shown in Figure 3 below. Embedded Image Data must be turned on for the HTML export. It is off by default, and without it the product images go to a separate folder named after the report, where browsers cannot load them if the work order name contains spaces or periods.
Create a report group and name it whatever you like; the example figures call it “HTML”. Add the reports 01_Work Order Summary, 06_Product Detail Report and 10_Master Parts Report, and set the Output Type dropdown to “HTML” for all three. Set the 11_Product Labels report to output as a PDF.
Under Group Options, set the group to print after processing a batch, check Create Subdirectory for Output Location from Name Modifiers, and set the output location to the Shared Network Path or drive you are using. Set the name modifier to Work Order Name only.
Create a second report group to generate the list of active work orders. Its only report is 00_Work Order List, also set to HTML output type. Set the report to generate after a work order is created, remove any name modifiers, and set the output location to the same Shared Network Path.
With both report groups ready, set up the HTML and PDF export settings to your preferences. We recommend the settings in the image below, including Embedded Image Data for the HTML export.
With your report groups set up, copy the drawing template and the script file for your platform to wherever you want to keep them. Then, on the palette, choose Microvellum Settings, then Options, go to the CAD tab, and click the Products in New Drawing Setup button.
Set your products to draw in 3D with full machining, then turn on “Run a Script after drawing the product” and browse to the script file you copied. Use ARGDrawProd.scr in Microvellum AC and ARGDrawProd_BSB.scr in Microvellum BSB. Under Template File, browse to the drawing template you want; Figure 4 shows the Imperial template. Click OK, and Microvellum applies the script and template to your next series of drawings.
The script Microvellum provides uses the X-ray visual style. We recommend setting that visual style's background color to white, which makes the output look much better.
Open a project and a room, then draw your products into individual drawings. In the Product Viewer, select every product you want in the work order, right-click, hover over Draw Selected Product, and choose Draw Selected Product(s) in New Drawing.
Microvellum draws each product in its own drawing, which gives you something close to a dynamic product image. In Microvellum AC, click one of the drawings in its individual tab to let the process finish. You will see the various angles, then a pop-up telling you the Plot and Publish job is complete.
In Microvellum BSB, there is nothing to click. Microvellum draws every product first, then runs the script on each drawing in turn and reports which drawings it finished. If the script stops before it completes on a drawing, Microvellum asks whether to run it on the rest. Drawing several products at once needs build 26.1.1125 or later; on earlier builds, draw one product at a time.
Once drawing is done, create a work order with the same products and process it as usual. Ensure that when creating the work order, it is set to “Manufacturing Active” status. Microvellum then generates all the reports and writes them to the location you created.
If you followed every step, the Shared Network Path now holds the Work Order List HTML file. It shows the work order you just processed, with links to the other reports in that work order's folder, so you can move between the product detail report, master parts report and part labels, and open the .dwg images embedded in the report. Set that page as the homepage on your shop devices, or at least bookmark it. Test every link in your paperless workspace, and repeat the steps for anything that does not work.
If the reports do not display properly, check that they landed in a folder named after the work order inside the output location.
Process other work orders the same way to add them to the paperless workspace, then reload the web page to see the updated list.
To show only active work orders, edit the completed or inactive ones out of the list with the Database Management utility. Open the list of work orders with Work Order Properties under the Tools tab, and set the status from ManufacturingActive to None or Completed. We suggest defaulting new work orders to either ManufacturingActive or Completed, depending on how many active work orders you want on the page.
