What
are the User permissions required by Toolbox?
Toolbox
software (the User) needs full permission to:
Registry Entries:
- HKEY_CURRENT_USER\SOFTWARE\Microvellum
- HKEY_LOCAL_MACHINE\SOFTWARE\Microvellum
Folders:
- C:\ProgramData\Autodesk
- C:\ProgramData\ Microvellum
- C:\Program Files\ Microvellum
(or wherever Toolbox was installed)
- C:\Program Files\Common
Files\Autodesk Shared
- C:\Users\{user}\AppData\Roaming\
Microvellum
- C:\Users\{user}\AppData\Local\
Microvellum
- C:\Users\Public\Documents\
Microvellum
- C:\Users\{user}\AppData\Local\Temp
Network Share:
SQL Database:
- Full permissions needed for SQL
Users/Groups (dbo)
- Groups need to be set to use
dbo Schema
Depending
on how your IT has your Group Policy set up, some of these may need to be
double-checked and corrected after install as well as updated in Group Policy.
