Saving a Product to the Library
This article explains the steps to save a product to the library.
- Select "Modify > Modify Products > Save Product to Library."
- Select the desired product to save to the library.
- Observe the "Save Product to Library" window.
- From the tree structure, select the category you would like to save the product to.
- Enter the desired name into the "File Name" entry box.
- Select "Save" and press "Yes" to the confirmation window.
The desired library product will now become usable within the specified category. For information about advanced library edits, see the Database Explorer.
Related Articles
Overview: Subassembly Save Options
Microvellum builds 15.5.1405 or higher required. The program has been modified to improve the flexibility of saving subassemblies. Previously, when creating a new subassembly, the program created the new subassembly in the library but did not create ...
Save Subassembly to Template Check Prompts (Reference)
The purpose of this article is to provide a reference for the new Subassembly Save Options interface. This reference applies to Toolbox builds 15.6.2201 and greater. See Save Subassembly to Template Check Prompts (Overview) in the Microvellum Help ...
Understanding the Subassembly Save Levels
Subassembly Save Levels When working in the Subassembly Prompts, there are different save options located at the bottom of the interface. Because subassemblies are shared across a project, multiple save levels have been incorporated to allow you to ...
Saving a Cabinet to Your Library
After a product has been created or modified, it can be saved to the library to be available for immediate use at any time. Select the Modify tab. Fig. 01 – Modify Tab Select Modify Products. Fig. 02 – Modify Products Select Save Products to Library. ...
The purpose of this article is to highlight the new interface and functionality when saving subassembly prompt(s) to the library level. When saving a subassembly back to the template and overwriting it, you can now check the modified subassembly ...
Recent Articles
Microvellum Foundation Library Release Notes | Build 24.0322
Additions Added the Master Angled Ends Cabinet. Added a Global prompt, "Hinge Plate Offset From Front" for easier control. Added “Double Division” option to Horizontal Designer Cabinets, 3 Door Cabinets, and other similar products. Added a new ...
Common Floating License Connectivity Issues
This document lists common issues reported by users regarding the topic of Microvellum’s Floating License Activation (FLA) and the connectivity required for FLA to function. Firewall Blocking Activation of Floating License Some users have had an ...
