Tutorial: Setting Door Center Panel Options
This video explains and demonstrates how to use the center panel options in the library build 048.
  1. Flat center panel option – rabbet joint.  (begin – 00:12)
  2. Modifying a raised panel to be b flat center panel.  (begin – 03:20)
  3. Center panel lookup table.  (begin – 04:10)
  4. Origin and location of center panels. (begin – 4:54)
    1. See the attached document for a picture that helps explain the origin.
