Subassembly Cabinet Modifiers
The video featured in this article covers the following subassembly modifiers:
  1. Base Arch Cutout
  2. Base Deco Cutout
  3. Base Three Sided Cutout
  4. Glass Insert
  5. Left and Right Chamfer Corner Flutes
To access the subassembly modifiers featured in this video, select Product Prompts > select the desired product.
Fig. 01 - Product Prompts
Right-click within the Product Prompts interface and select Subassemblies.
Fig. 02 - Subassemblies
From the Subassemblies Interface, the Cabinet Modifiers menu is located within the left-hand pane.
Fig. 03 - Cabinet Modifiers Menu
    • Face Frame Modifiers
      The video featured in this article covers Face Frame Modifier Subassemblies, which include:  Bottom Rail Arch Bottom Rail Double Arch Bottom Rail Scallop Bottom Rail Three Sided Notch Left Stile Chamfer Corner Flutes  Left Stile Flutes and Profiles ...
    • Understanding What a Subassembly Is
      Understanding What a Subassembly Is Subassemblies are smaller products inside of another product. Subassemblies are also shared within a project. For example, the subassembly, Carcass Base, is shared across all the base cabinets in a project.  The ...
    • Adding Subassembly Inserts and Using Pick Corners
      Adding Subassembly Inserts and Using Pick Corners The lists of subassemblies within the product starters may not contain a particular subassembly. In that case, a subassembly will need to be added to the product. The Subassemblies interface will ...
    • Tutorial: Modifying Opening Splitter Subassemblies
      How do you customize the opening space in a product? The following tutorial uses a Vertical Tall Starter with two bays to demonstrate two methods of using splitter subassemblies to customize product openings or bays. Why are the splitters named the ...
    • Understanding the Subassembly Save Levels
      Subassembly Save Levels When working in the Subassembly Prompts, there are different save options located at the bottom of the interface. Because subassemblies are shared across a project, multiple save levels have been incorporated to allow you to ...
    • Toolbox Release Notes | Build 23.1.0605.641
      Report Groups Fix A fix has been made to resolve an issue that reportedly caused errors when report groups attempted to print manually. Fixes and Additions to Part Properties Toolbox Console->Part Properties/Toolbox Setup->Options 2D drawing tokens ...
    • Toolbox Release Notes | Build 23.1.0525.641
      Hardware Machine Token Tool Compensation Fix Users reported an issue that caused hardware machine tokens to produce tool compensation incorrectly. This issue has been examined and resolved. Work Order Cancellation Fix Microvellum Console->Settings ...
    • Toolbox Release Notes | Build 23.1.0523.641
      Toolbox Release Notes | Build 23.1.0523.641 Face 6/Horizontal Drilling Enhancement Toolbox Setup->Options->Toolfiles->Double-click specific Toolfile->Integrated Post Processor Settings->Settings Users will now be able to cut down on file management ...
    • Foundation Hardware Highlight: Blum
      Microvellum’s Foundation Library is built on the premise of providing our users with the best quality hardware for their construction projects, be they commercial, residential, or anything otherwise. As such, Toolbox has hardware from multiple brands ...
    • Microvellum Foundation Library Release Notes | Build 23.0517
      This update includes many changes & additions to the Microvellum Face Frame expansion. Not all users will have access to these special products. Contact your account manager for more information. Additions: Added new drawer system Rocheleau R13 EVO ...
