Toolbox BSB: Supported File Extensions for Import/Export
Toolbox BSB, using BricsCAD Pro as its basis, offers full support for the same wide range of file types for import and export. Certain file formats not listed in this article can be imported/exported by BricsCAD, but are not, at the time of writing, available for import/export in Toolbox BSB. These file types may become available in future versions of the software.
CAD File Formats
CAD formats are file types that are either native to or available for usage in CAD software. Toolbox BSB supports the following file types for import or export. File types are marked according to whether they can only be imported or exported, or both. File types created specifically for use with BricsCAD (such as settings files or are designated as native files in the Import/Export column. Some file types capable of being imported (such as SketchUp files) may be imported in a state that requires an additional step to be usable in BSB (SketchUp files are imported as meshes, and require one to use the SOLIDIFY command, as noted below).
CAD Formats
Extension
Description
Import/Export
FBX binary file
FBX
A Mudbox format used to send 3D models to animation and rendering software. Can be exported using the FBXEXPORT command.
Export only
FBX ASCII file
FBX
An ASCII format (readable on the user end) version of the FBX format. Can be exported using the FBXEXPORT command.
Export Only
AutoCAD® Drawing
DWG
CAD drawing format created by Autodesk®. To export drawings in an earlier DWG version, use the SAVEAS command.
Import/Export
AutoCAD® ASCII DXF
DXF
Drawing interchange format created by Autodesk®; to create binary DXF files, use the DXFOUT command.
Import/Export
Drawing Template
DWT
Templates on which new drawings are based.
Import Only
3D DWF
DWF/DWFx
CAD viewing format for 3D models created by Autodesk®. Can be exported using EXPORT command.
Export Only
Binary DWF
DWF
Compressed version of DWF.
Export Only
Zipped ASCII Encoded 2D Stream DWF v6.0
DWF
ASCII version of DWF compressed into a ZIP file.
Export Only
Compressed DWF v5.5
DWF
Compressed ASCII version of an older version of DWF.
Export Only
Binary DWF v5.5
DWF
Compressed version of an older version of DWF.
Export Only
ASCII DWF v5.5
DWF
Export Only
MicroStation DGN File
DGN
Design files created for use with the MicroStation CAD software. Imported using the IMPORT command.
Import Only
Rhino Files
3DM
3D modeling file for the Rhinoceros CAD application software. Imported with the IMPORT command.
Import/Export
LandXML
LANDXML
An XML format designed to contain survey/civil data. Can be imported/exported using the LANDXMLIMPORT/LANDXMLEXPORT commands.
Import/Export
SketchUp file
SKP
SketchUp model files. When imported, they are imported as meshes. The model can be converted into a solid using either the SOLIDIFY command (if intending to only convert a mesh to a solid), or using the CONVTOSOLID and CONVTOMESH commands (if intending to convert back and forth between a mesh and a solid).
Sketchup files are imported using the IMPORT command.
Import Only
Standards File
DWS
Drawing standards file, used by the STANDARDS and CHECKSTANDARDS commands.
Import/Export, Native
Vector Formats
Vector files are images coded with geometric formulas to enable them to be scaled with minimal quality loss. BricsCAD allows for the import and export of multiple different vector file formats. Specific formats have additional functionality tied to their import, as noted in the table below.
Vector Formats
Extension
Description
Import/Export
Windows Meta File
WMF
Vector format created by Microsoft and used by the clipboard; can be exported using the WMFOUT command.
Import/Export
Enhanced Windows Meta File*
EMF
Updated version of the WMF file format.
Import/Export
Scalable Vector Graphics
SVG
An XML-based file format for describing two-dimensional vector graphics. Used by Web pages to display vector graphics.
Multiple commands control the files; it can be exported using the EXPORT command.
Export Only
Lithography
STL
A 3D format used by 3D printers, native to the stereolithography CAD software created by 3D Systems.
Can be exported using the STLOUT command.
Export Only
Collada file
DAE
A 3D format used by rendering and animation software. Imported and Exported using the IMPORT/EXPORT command.
Import/Export
Slide File
SLD
Proprietary graphics format created by Autodesk® for saving screen grabs of viewports. Can be created using the MSLIDE command and viewed using the VSLIDE command.
Export Only
3D PDF**
PDF
Portable Document Format (PDF) is a file format used to represent documents, independently from application software, hardware, and operating system. PDFs have a variety of associated commands in BSB, including PDFIMAGECOMPRESSION, PDFVECTORGEOMETRY, PDFIMPORTIMAGEPATH, and more.
Import/Export
HTML Format
Extension
Description
Import/Export
HTML
HTM
Hyper Text Markup Language format files are opened in a Web browser. The VMLOUT command exports drawings to VML (short for vector markup language) embedded in a HTML file.
Export Only
Wavefront Object File
OBJ
A text file format which contains 3D graphic information such as vertices, polygonal faces, and 3D coordinates. Can be imported using the IMPORT command.
Import Only
Raster Formats
Raster image file extensions that are available for import into Toolbox BSB. It should be noted that while the most common raster formats are not listed in this chart, JPEG, JPG, and PNG files are able to be imported and interacted with while using Toolbox BSB, for specific purposes (such as being set as a logo in paper-space or added to a specific drawing).
Raster Format
Extension
Description
Import/Export
Bitmap
BMP
Raster format created by Microsoft; used by the clipboard. Can be imported and exported using the IMPORT/EXPORT commands.
Import/Export
Point Cloud Formats
Point Cloud files contain data points collected for the purpose of analyzing geographical regions, terrain, buildings, or space. Toolbox BSB, being built using BricsCAD Pro, allows for the import and export of multiple different Point Cloud files. Generally, all the file types listed below can be imported into BSB using the POINTCLOUDREFERENCE command, then selecting to import a file.
Point Cloud Format
Extension
Description
Import/Export
LIDAR Data Exchange
LAS
Open binary format created by the ASPRS to create maps and models of recorded areas. This is the standard format of LIDAR data.
Import Only
LIDAR Data Exchange Compressed
LAZ
A format designed to contain compressed LAS files without data loss.
Import/Export
Hexagon Smart Point Cloud
HSPC
A point cloud format that utilizes specialized coordinate encoding to enhance point collection for data. Created to replace the HPC format; used by Hexagon.
Import/Export
Hexagon Smart Point Cloud Pack
HSPC.Pack
HSPC files that contain multiple clusters of data, rather than a singular set.
Import Only
E57 ASTM Standard
E57
A vendor neutral format for storing point cloud data, images, and metadata.
Import Only
Leica Geosystem
LGSX
3D scan files that contain raw survey and mapping data. These files are native to the Leica Cyclone software.
Import Only
Plain Text Point Data
PTS
A Leica native format containing point cloud data that does not retain data from the original scan or registration.
Import/Export
Plain Text Point Data Extended
PTX
An ASCII format based on the PTS that saves 3D data points as 4 or 7 values. This format retains all scan and registration information upon export.
Import Only
ReCap Project
RCP
A file format containing an aggregation of multiple RCS files. Designed for use with Autodesk ReCap.
Import Only
ReCap Scans
RCS
A file format containing data from either one or multiple scanners. Used primarily by Autodesk ReCap.
Import Only
RiScan Pro File
RSP
A file format for RiSCAN Pro projects.
Import Only
RiScan Pro Point Cloud Data
RDBX
The proprietary database extension format for RiSCAN Pro.
Import Only
Zoller Frohlich File
ZFS
The binary format for gridded point cloud data gathered using Zoller+Frolich scanning devices.
Import Only
