Toolbox Release Notes | Build 20.1.1216.641
The following release notes apply to Toolbox Build 20.1.1216.641.
2D Part Editor
Resolutions:
  1. Resolved an issue with saw cut direction producing an error when picking an existing line on the X axis.
  2. Resolved an issue where associative hardware was no longer attached to the part after updating from single part editor. Also, unless the hardware is modified, it updates with original formulas.
Machine Tokens
Resolutions:
  1. Resolved an issue where setting a depth of a route to greater than the panel thickness would get incorrect 3D representation.
  2. Resolved an issue where using keywords in a token’s description could interfere with the token machining.
  3. Resolved an issue where border bulges were incorrect if an AutoCAD drawing was created using ERP or Server.
Part Properties
Resolutions:
  1. Resolved an issue where errors in token parameters could not be easily identified from the Part Properties UI.
CPOUT Enhanced
Resolutions:
  1. Resolved an issue where CPOUT Enhanced was not rounding correctly.
MV Commands
Resolutions:
  1. Resolved an issue where the MVSUBASSEMBLYPROMPTS command was not working from the command line.
  2. Resolved an issue where the Draw All Products in Category command was not working as intended. Now products are being drawn in order according to how the library is set up.
Specification Groups
Resolutions:
  1. Resolved an issue where deleting a spec group left behind the material file components.
  2. Resolved an issue where adding a formula material would add it to the spreadsheet twice.
Modifications:
  1. Modified Spec Groups to include a check when deleting a spec group ensuring that it is not currently being used.
Nest Composite
Resolutions:
  1. Resolved an issue where updating or making new gcode from the nest composite would offset the setmill pointer to indicate tool comp instead of staying centered on the tool path.
  2. Resolved an issue where Plot Nests was not maintaining layout.
Labels
Resolutions:
  1. Resolved an issue where the Face 6 image was not showing in auto-labels when it was dependent on the Optimization Result Face 6 barcode.
  2. Resolved an issue where HBore barcodes were not being associated to the nest when processed along with single part processing stations.
