Toolbox Release Notes | Build 21.1.0519.641
The following Release Notes apply to Toolbox Build 21.1.0519.641
Processing
Resolutions:
Resolved issue where part border Xdata would not write the correct LinkIdOptimizationResult after creating new g-code from drawing.
Resolved issue where first-time processing with nest "face5filename" and "barcode" was not populated into the optimization results table in the database.
Resolved issue where updating a nested part border in the nest drawing, 2D part editor would erase the part border and add a new one, but not transfer the Xdata from the older border to the new one.
Resolved an issue where even with Include Routes In Borders (IRIB) turned OFF, IRIB would still be applied if True Shape Nesting was set above 40%.
Specification Groups
Modifications:
Modified the Delete Specification Group functionality to give the option of saving unique components within the specification group instead of deleting them automatically.
Resolutions:
Resolved an issue where copying a Project Specification Group without checking any components to be copied with it resulted in an error when opening one of the components.
Edit Design Data
Resolutions:
Resolved an issue where redrawing a product with Edit Design Data while having a plan view of the product would move the product incorrectly.
Resolved an issue where selecting
"apply formula" in the product level prompts tab, subassemblies tab, or hardware tab of Part Properties would result in an object reference error.
