Toolbox Release Notes | Build 21.2.0127.641
The following Release Notes apply to Toolbox Build 21.2.0127.641
3D Drawing
Resolutions:
  1. Resolved an issue where the DRAWMOLDING FaceFrameRail drawing token would cause an error in Part Properties.
Edit Design Data
Additions:
  1. Added a message box to warn about unexpected results when the spreadsheet culture option and UI language option are not the same.
Resolutions:
  1. Resolved an issue where Edit Design Data would not prompt to save a nested subassembly if the main subassembly was changed from the Product workbook.
  2. Resolved an issue where molding from the DRAWMOLDING token would continue to draw duplicate parts and would not add xdata to the part in the L workbook.
  3. Resolved an issue where the user was not asked to save after making a change in Workbook Designer and then closing Edit Design Data.
  4. Resolved an issue where Edit Design Data would allow you to select a product from a project that was not currently open causing the product to be orphaned in the database.
Machine Tokens
Resolutions:
  1. Resolved an issue where adjustable shelf holes would run in the wrong direction after rotating a part.
Part Processing
Additions:
  1. Added backward compatibility with v67 when updating or creating new g-code in a Room.dwg.
Resolutions:
  1. Resolved an issue where valid data was being overwritten with blank cells when processing a nest with processing station associates.
  2. Resolved an issue where barcodes were being added to all parts with associate processing stations.
  3. Resolved an issue where a horizontal bore tool file and processing station created a face 6 barcode on parts with face 6 machining.
  4. Resolved an issue where extra copies of the Num(#) Column were added in the Processing Center after changes were made to a processing station.
Workbook Designer
Resolutions:
  1. Resolved an issue when modifying and closing the "M" workbook without saving changes, library materials are overwritten by project materials in Workbook Designer.
