Toolbox Release Notes | Build 22.1.0831.641
The following Release Notes apply to Toolbox Release Notes | Build 22.1.0831.641
User Interface
Resolutions:
  1.  Resolved an issue in the Edit Formula Materials UI that caused the window to not grow/shrink like it should.
  2.  Resolved an issue in the Edit Formula Materials UI that would cause an error to appear when you click ‘Apply’ if the data is blank.
  3. Resolved an issue where accuracy settings were not refreshing correctly when switching between fractions and decimals.
  4.  Resolved an issue that prevented removing the Worklist File Path in H-bore processing stations.
Modifications:
  1. Corrected a few grammar mistakes in the Processing Center and some Processing Stations.
  2. Removed a lingering un-used button in the Project Properties (Correspondence Attachments)
  3. Drop down lists (i.e. combo boxes in Product Prompts) are now capable of showing trailing zeros.
  4. Added ‘Formula Driven Aliases’ to the selected items in Database Management when importing/exporting materials.
  5. Improved the ‘2D Tools & Parts List’ to include the row numbers of each part:
 Hardware
Resolutions:
  1.          Resolved an issue that caused hardware with ‘Skip Spreadsheet Sync’ enabled to lose association to its product in the database.
  2.          Resolved an issue where adding more than 1 hardware via the ‘2D Part Editor’ would not work.
 Saw Barcodes & Labels
Resolutions:
  1.          Resolved an issue that caused a saw processing station to sometimes not create face 5/6 barcodes.
  1.        Resolved an issue that caused the part label to reference a different part than the output file for certain saw types.
