The following Release Notes apply to Toolbox Build 22.1.0901.641
General Settings
Resolutions:
- Resolved an
issue with the ‘Default Name of Project Locations’ setting. The project name
was not being carried over when creating new rooms, or when trying to copy or delete.
User Interface
Resolutions:
- Resolved an issue that addresses copying products in the
product list that would cause your selection to jump to the top of the list.
- Resolved an issue with the ‘already printed’ saw
patterns in the Processing Center where it was not showing when they have already been printed.
- Resolved an issue that made item numbers in
composite drawings round incorrectly.
Projects
Resolutions:
- Resolved an issue with project titles containing a
period that caused rooms to be disconnected from their respective project.
Modifications:
- You can now double-click categories when moving and
copying projects.
Work Orders
Resolutions:
- Resolved an issue that caused the software to freeze
and fail without warning whenever attempting to create a work order from a
product with a quantity of 0.
- Resolved an issue that caused work orders to be
missing from the ‘Work Order Selection’ UI if they contained leading or double
spaces in the title.
- Resolved an issue that let a user create a work
order with a comma in the title. That is an illegal character and caused issues
down the line.
- Resolved an issue with the ‘Work Order Status’ being
“In Queue” that prevented the work order from being opened via ‘Modify Work
Order’.
Resolutions:
- Resolved an issue with some IPP tool files that
caused extra folders being generated in the specified G-code path.
- Resolved an issue and changed the help text when
using a PLINE machine token to do a pocket route. Tool priority is working as
intended now and the help text has been improved so it is more clear.
Product Prompts
Resolutions:
- Resolved an issue with the search feature in Product
Prompts that was finding prompts that were not associated with the product.
- Resolved an issue that allowed a user to use the ‘Show
Subassembly Prompt’ command on products that were not in your current project.
- Resolved an issue when trying to save a subassembly
to the library via ‘Show Subassembly Prompt’. It no longer errors out after the
first save and cancels correctly now.
XML
Resolutions:
- Resolved an
issue that prevented using the ‘Export Work Order Data as XML’ on a unified
work order database.
- Resolved an
issue when importing an XML that caused the specification group to be
incorrect.
Modifications:
- Users can now
use a category tag within the XML to specify what category the new project is
imported into.
