Toolbox Release Notes | Build 22.1.0920.641
Machine
Tokens
Resolutions:
- Resolved an
issue that caused shelf holes and shelf standard machining to run horizontally
instead of vertically.
Materials
Resolutions:
- Resolved an issue that prevented the hardware wizard
from changing more than one piece of hardware at a time.
- Resolved an issue that caused material changes to
revert if they were made with the find and replace in the template material
file.
Winstore (Biesse)
Resolutions:
- Resolved an issue that caused any manually added
scrap to be given the wrong operation after pulling it from inventory and
committing it back.
- Resolved an issue and moved the code around that
caused an extra “DROP_lbl.xml” file to be output. This caused some machines to
error out.
caused the material name to always be the material handling code.
