Toolbox Release Notes | Build 22.1.1105.641
The following Release Notes apply to Toolbox Build 22.1.1105.641
Auto-Labeling
Resolutions:
• Resolved an issue with auto-labels not incrementing correctly when parts had multiple quantities.
Nest Editing Tools
Resolutions:
• Resolved an issue that prevented a user from adding parts to a composite nest drawing.
Materials
Resolutions:
• Resolved an issue that caused saving materials to take an abnormally long time.
Product Prompts
Resolutions:
• Resolved an issue that stopped the product prompt help images from appearing.
• Resolved a couple of issues around “Use Previous Product Comments”. This check box in product prompts will now function correctly.
WMF Image
Modifications:
• Modified WMF images on part reports to appear more clearly, especially with small parts.
Tool File
Resolutions:
• Resolved an issue when replacing face 6 machining on multiple quantities of the same part.
• Resolved an issue where the worklist file path was being incorrectly generated causing the .dat files to not be saved when "Shorten GCode Output Path" was selected.
• Resolved a few minor UI issues related to wording and grammar.
Modifications:
• Modified the <RL> custom string tag and added “wild card syntax” functionality. See more information regarding the new custom string in the Overview: Integrated Post Processor Tool Files (IPP) article.
• Modified the “Export as TLFX” feature to check and prompt to overwrite. It will also notify the user when the export has been completed.
Drawing Products
Resolutions:
• Resolved an issue that caused the wrong product to be drawn after certain steps were taken.
