Toolbox Release Notes | Build 23.1.0208.641
The following Release Notes apply to Toolbox Build 23.1.0208.641.
Saw Scrap Label
Modifications:
- Added a setting to turn on/off material trim for scrap on the edge of a sheet (defaults to on to prevent breaking changes).
Nest Drawing
Resolutions:
- Fixed an issue with imperial unit PTP stations causing material thickness to change to metric values when using “Update Gcode” with “Convert to Metric” setting enabled.
Report Images
Resolutions:
- Fixed an issue that caused the images of flipped parts to be blurry in the reports.
Flatshot Tokens
Resolutions:
- Fixed an issue with certain part dimensions causing “Hidden View” to stop working.
- The word “miter” in flatshot token formulas will no longer cause the part to draw incorrectly.
- Hardware now appears in Component Library Dynamic Product Images.
Resolutions:
- Fixed a null reference error encountered when processing an order with auto labels and “RunFace6First” enabled.
User Experience
Resolutions:
- Importing a duplicate tool file will no longer cause users to be stuck in an infinite loop after trying to cancel the Resolve Duplicates window.
- Fixed a project vanishing from the list when attempting to delete its .dwg while it's open.
- Added Scheduled Start Date title block attribute in Project Properties.
- Several commands no longer result in Unhandled Exception error when ESC key is pressed.
