Toolbox Release Notes | Build 23.1.0613.641
The following Release Notes apply to Toolbox Build 23.1.0613.641
Edge Band Materials Fix
  1. An error was reported that caused project edge band materials to overwrite the template records if a user ran “find and replace” and then “Add Component From Template” in the material file. The issue has been resolved.
Prompts Fixes
  1. There has been a noted issue wherein rapidly clicking on prompts duplicated them or failed to add them at all. This error has been resolved and removed.
  1. Moving a newly created room after using "Edit Additional Prompts" will no longer error.
  1. The first column in the prompts list had an issue wherein it did not reset when refreshed. This has been changed, to avoid any further refresh issues.
IPP Tool File Fixes
  1. Certain Biesse machines had issues with lead-ins when using common-line nesting. The issue has been resolved.
  1. Users reported an issue wherein Morbidelli machines used incremental step tools that caused the final pass in G-code to duplicate if the token depth was greater than the step depth and material thickness.  The issue has been resolved.
