Toolbox Release Notes | Build 23.1.0718.641
The following Release Notes apply to Toolbox build 23.1.0718.641
Saw Output Fixes
  1. When compiling G-Code, the saw output sometimes included invalid characters, causing cuts to occasionally miss or code to be rejected by the system. This has been resolved.
  2. When processing work orders, it was reported that part comments did not appear in XML files if one’s global file had perfect graining enabled. This has been resolved.
WMF Generation Fix
  1. An issue was reported wherein WMF images would be created in Cutrite ASCII processing stations, even if the setting was disabled. The issue has been resolved.
Processing Station Fix
  1. Processing stations were noted to have significant time lag, with assigning and unassigning a large amount of processing stations taking several minutes, potentially even crashing the program. The efficiency of this process has been drastically improved.
    1. It took 70 processing stations with 1920 parts up to 10 minutes to process a work order. With the overhauls made in processing, it has now been recorded taking as little as 20-60 seconds.
These figures derive from testing with the data and setup utilized by the Microvellum quality assurance team- user results may vary.
Felder IPP Tool Files Fix
  1. An issue was reported wherein the Felder IPP tool file did not produce G-Code in separate material folders, even when the setting was enabled, and a path was set. This issue has been resolved.
