Toolbox Release Notes | Build 23.1.1020.641
The following release notes apply to Toolbox build 23.1.1020.641
Corner Cabinet Dado Fix
Figure 1: Dado Corner Cabinet routing issue.
Figure 2: Dado Corner Cabinet routing fix.
  1. Users reported an issue when creating corner cabinets with dado construction in their projects- the dado in the upper left portion of the cabinet, when assigned to route, was not routing correctly. There was also an issue for users creating cabinets and applying dados to backs, specifically when using the “Stop Dado Thick Back” global, it was reported that sometimes, the dado would ramp incorrectly, moving diagonally. This issue also was reflected in the G-code when the product was processed. This issue has been resolved- dados should now route correctly in corner cabinets, as well as ramp correctly in backs.
Change Setmill Fix
  1. There was a noted issue with part borders when attempting to change the location of setmill on a route. When changing the location of setmill on a route and updating the G-code, the setmill would not move, instead placing a line break in the middle of the route (dividing it in two). This issue has been resolved- setmill should now be relocated when attempting to change the location on the part border.
