The following release notes apply to Toolbox build 23.1.1212.641
FLA Session Management
Figure 1: Session Management UI | Figure 2: Session duration set. |
There was a noted concern with sessions on Microvellum closing and checking out
of sessions if the software were to crash, due to FLA necessitating connection and the software being active to keep sessions open. To address this, sessions have had their FLA certificate set to allow for the management of the time of the session, with users able to reserve the concurrent spots available for their individual devices based on a set time limit. The session management UI has been added to allow for the manual setting of timed durations in order to ensure crashes do not adversely affect client ability to access the software.
Project Level Materials Fix
Figure 3: Project level material not being reproduced with dimension information.There were a few issues noted with different project level materials not registering or retaining value when created in the project, requiring a restart of the project or use of the “Sync from Database” option. This issue reportedly occurred in 3 different ways:
- Perfect graining would not register as being applied when applied to a created project level material.
- Edgebanding would fail to appear in processed work orders when changing edgeband materials or creating a new Edgeband material.
- Projects with project level materials already added under the project-level material category would reproduce the materials in the copied project, but the materials would lack any tooling or graining information.
- These issues have all been resolved- project level materials should be able to be replicated and retain their values when placed into a new project.
Border Cuts Fix
- Users reported an issue with border routing during Stay Down Nesting, wherein the border pattern would skip over some parts for routing, but not others. This would appear in the G-code when run through 3rd party programs, with some border routes not appearing at all.
- This issue has been resolved- Stay Down Nesting should now register the border cuts and assign them to all parts.
Figure 4: SMA rectangular pockets missing.
| Figure 5: SMA pocketing issue fix; all pockets machined. |
- There was an issue reported when processing a part with rectangular pockets, wherein users would be informed that the tool file does not have a tool with the necessary diameter to perform the operation. This would subsequently lead to issues of some pockets being machined, but others not receiving any machining in the slightest.
- This issue has been resolved- there should no longer be an issue with the tool file registering the proper tool, and when rectangular pockets are created, all should have machining.
- SS tool files with “optimize vertical drilling” and “sort vertical drilling by tool drops” enabled were reportedly having an issue wherein the tool drops would be sorted incorrectly. Rather than sorting in accordance with tool number (diameter/same banking binary), the drill holes would be sorted somewhat randomly, with incorrect groupings of tool numbers. The drill operation would subsequently use an incorrect order when performing.
- This issue has been resolved- vertical drills in tool files should now sort tool drops correctly, and drill operations should commence without this issue appearing.
