Toolbox Release Notes | Build 24.1.0108.641
The following release notes apply to Toolbox build 24.1.0108.641
Face 6 Filename Fix
  1. Users reported an issue with face 6 machining files, wherein after nesting a batch and examining the resultant G-code, they found that the face 6 barcode would be altered to have a filename with an extra “1” character added, leading to problems with certain machines operating, due to the maximum character limitation of 8 being exceeded with the additional “1”.  This issue has been resolved- face 6 machining files should no longer have an additional character added, eliminating any issues of invalid file names.
Copied Product Name Fix
Figure 1: Copied product reverting name.
  1. There was an issue occurring when users attempted to copy a product within their Product List, renamed the product or gave it different specifications, then opened their parts list, wherein the product would revert to its original name, while retaining the other new specifications. This issue has been resolved- copied parts within the product list should now retain their new names and properties without reverting.
Replace Product Name Modification
Figure 2: "Replace Products" name change to "Replace Product Prompts".
  1. The “Replace Products” button has been deemed to cause unnecessary confusion to users by merit of its name, and as such, has been altered to “Replace Product Prompts” to reflect its function more accurately.
Product/Part Comment Fix
Figure 3: Product and Part comments Custom Settings issue resolved.
  1. Certain users utilizing part or product comments via the Custom Settings tab in a Saw Processing Station found that after processing they would show up incorrectly or missing in the output file. This issue has been resolved- product and part comments should now display separately when input into a station.  For instance, in an example with Product Comments containing "Hello|World|Test".  Product Comments would output "Hello|World|Test".  Product Comment 1 would output "Hello".  Product Comment 2 would output "World".  Product Comment 3 would output "Test".
Session Checkout Time Fix
  1. There was a reported issue from certain users who found that their FLA based session in session management would sometimes add on an additional few minutes before the session expiration time, leading to confusion. This issue has been resolved; the FLA session timer should now accurately reflect their exact input time without issue.
