Toolbox Release Notes | Build 25.1.0114.641
The following release notes apply to Toolbox build 25.1.0114.641.
UI Fixes
Several issues were reported and discovered within the OEM 2025 user interface. The following issues have been resolved:
Fig. 1: Excess commands on the tool strip being dropped (left) and being displayed in a pop-out menu (right).
  1.  An issue with the tool strip of the Toolbox palette was resolved. When one’s tool strip reached the maximum UI capacity for commands, the extra commands, rather than simply appearing on a pop-up menu on the bottom of the strip (as they are intended to), would instead disappear from the tool strip entirely, essentially limiting the number of commands one could place.
Fig. 2: The checkmark of "Select Entire Product" being off center.
  1. An issue of the checkbox within the Select Entire Product option being noticeably off-center in its alignment has been resolved.
Fig. 3: The lower set of palette options failing to wrap.
  1.  When adjusting the size of the Toolbox palette, an issue was found with the wrapping of certain buttons. While both sets of buttons within the palette are intended to wrap to ensure that different functions remain visible, the lower set did not appear to do so. This led to some functions disappearing. This issue has been resolved.
Fig. 4: Global variable colors not matching (left) and matching (right).
  1. A graphical issue has been resolved in the global variables. When creating a new category of global variables (or simply new global variables), users who assigned these variables colors found that the associated values or checkboxes would mismatch with the variable’s text color.
Fig. 5: The option separation bars not disappearing from a pop-up menu.
  1. A graphical issue that was occurring in pop-up interfaces has been resolved. Some users found opening more than one pop-up menu during a Toolbox session would result in situations wherein the bars separating different sets of options were remaining on-screen in the interface. This was occurring even if the menu being opened didn’t have multiple sections of related options.
Fig. 6: An issue of digit cutoff in the Processing Center UI.
  1. A graphical issue with the Processing Center’s UI was resolved. This graphical issue would occur when users processed orders with a part quantity greater than 1000, which would sometimes result in the first two digits of the part count cutting off of the screen.
Fig. 7: The letters Y and G being cut off in the design data interface.
  1. A slight graphical issue with specific letters (y and g) in the design data interface has been resolved. The lower halves of the letters were being cut off by the UI.
Fig. 8: The missing pin in the Product List UI.
  1. An issue within the UI of the Product List has been resolved. Some users found that the Control Panel’s pin icon (used for hiding the interface) was missing, preventing users from hiding the Control Panel.
  2. Another issue within the Products List UI has been resolved. When users attempted to create groups with their categories in large projects, they would experience an unhandled exception error.
Fig. 9: Oversized buttons in the MVProduction UI.
  1. An issue with MVProduction regarding uneven button sizes has been resolved. Uneven or oversized buttons in certain parts of the ribbon were leading to erroneous clicking of certain options.
