Toolbox Release Notes | Build 25.1.0403.641
The following release notes apply to Toolbox build 25.1.0403.641
Trueshape Fix
Fig. 1: A bounding box drawn around the container of a part with True Shape nesting applied.
  1. An issue was reportedly occurring when processing parts with True Shape nesting applied. Namely, parts with True Shape Nesting applied would sometimes have the position of the part be calculated incorrectly. This issue has been resolved- a coding change has been applied to ensure that the X and Y coordinates of parts with True Shape nesting applied calculate correctly.
PTX Handling Code Option
Fig. 2: The new "Use Handling Code" checkbox.
  1.  A new checkbox option has been added to the Saw Processing Station UI for use with PatternExchange type saws, called “Use Handling Code”. When enabled, this option sets the optimizer to process materials using the material’s handling code rather than the material name. While this option exists in the Saw Processing Station UI regardless of output, it is currently only functional when using a PatternExchange output type.
