This video explains the differences between the various type of door data (door libraries) contained within the Microvellum Library version 048 and where that data is located. You will see how the appearance of the prompts page adjusts based on the ...
This video demonstrates where the solid wood door profiles originate and how to configure new profiles. Where the profiles are coming from. (begin – 01:08) Understanding profiles. (begin – 08:51) Profiles and machine tokens. (begin – 12:00) Entering ...
Adding 3D and 2D Images for a Custom Pull The following article instructs users on the process of creating a custom pull within the legacy Microvellum Component Cabinet Library. For information on how to create and implement custom pulls into your ...
The Door Data in the Microvellum Library v048 and greater has been significantly improved! The improved data is seen mainly in the solid wood panel doors, whereas the MDF and slab doors are relatively unchanged. This video gives a partial list of ...
