Tutorial: Library Build 048 - Door Data and Wizard
Tutorial: Library Build 048 - Door Data & Wizard
This video explains the differences between the various type of
door data (door libraries) contained within the Microvellum Library version 048
and where that data is located.
You will see how the appearance
of the prompts page adjusts based on the door data option selected.
It demonstrates how to access the
Door Wizard through the Advanced Library Setup sub-component named "Door
Wizard Components" Another way to look at the data accessible in this
interface is that it is door level global variables.
Another way to access this data,
if it will be the same between products, is from the Project Wizard > Door
Styles. All changes made in the Project Wizard will also be displayed in the
Door Wizard.
The Door Wizard may also be
modified in the spreadsheet environment, in the "D" workbook. This
interface gives you a better understanding of how all the data works together
and how it is possible to adjust your door data to your company standards. (The
video contains a tour of the various parts of the lookup tables in the
spreadsheet.)
One of the types of data that the
D workbook contains is the reference to the AutoCAD profile drawing that is
used when creating the doors.
The Door Data in the Microvellum Library v048 and greater has been significantly improved! The improved data is seen mainly in the solid wood panel doors, whereas the MDF and slab doors are relatively unchanged. This video gives a partial list of ...
This video demonstrates how to maximize the default features of the Microvellum Library Solid Wood Doors. How to use the prompts and why various prompts are visible at different times. Also, how the dropdown list boxes are populated. How to use the ...
This article summarizes the Project Wizard, Global Variables, Material Files, and Door Wizard Interfaces within the Library Specification Groups. For a general understanding of Library Specification Groups, see: Understanding the Library ...
This video explains and demonstrates how to use slab moldings on doors and drawer fronts. This includes the use of a molding applied to the face of the door panel and a molding that is a perimeter part. Fig. 01 Definitions of different types of slab ...
If your license is current, but you keep getting the Activate Software window when starting up Toolbox, this is the fix. Instead of entering your serial number and password every time, go to your MV Toolbox icon on your desktop and Right-click then ...
The following Release Notes apply to Toolbox Build 22.1.0620.641 Reports & Labels Resolutions: Resolved an issue with the auto-label rotation when you create new g-code from a batch drawing. Resolved an issue with certain saws that prevented the ...
The following Release Notes apply to Toolbox Build 22.1.0607.641 Report Groups Resolutions: Removed and extra "BMP" choice for the HTML format. Resolved an issue that prevented changing the scaling in HTML output. Resolved an issue that caused ...
The following Release Notes apply to Toolbox Build 22.1.0525.641 Database Management Resolutions: Resolved an issue that caused products and subassemblies to need to be imported twice in order to see them in Toolbox. Resolved an issue with ...
The following release notes apply to Microvellum Foundation Library, Build 22.0520 Please make sure you are selecting the correct specification group when drawing products. There may be specification groups for both metric and imperial. Additions: ...
