The articles in this section of the Knowledge Base involve working with the Sub Report component for display in your reports. To access the Report Designer, select Toolbox Setup > Design Reports > Design (Report Type) Report. Select New Report to design a report from scratch or New Report from Existing. Select Designer to open Report Designer.
From this screen, add a Sub Report component to your report, or edit an existing sub report component.
It is possible to display a report within the current report using the Sub Report component. When a report with Sub Report components is rendered, the report engine builds all the nested reports and place them within these components.
Sub Reports can be placed on:
A report to display in the rendered report using the Sub Report component can be obtained:
