How to Uninstall Toolbox AC (AutoCAD Companion)
These procedures explain the removal of Toolbox 2020 AC (AutoCAD Companion) and supporting files while using Windows 10.
- Select the “Windows start icon”.
- Select “Settings”.
- Select “Apps”.
- In “Apps and Features” scroll down until you find “Microvellum Toolbox Standard x64” and select it.
- Select “Uninstall” through all the prompts.
- You will be notified with the message “You have successfully uninstalled this product” when Toolbox AC has been uninstalled.
Removing Microvellum Data from Your Registry
WARNING – Microvellum is not responsible for modifications made to the registry. Improper edits may render an operating system unusable. For more information visit Microsoft support.
- Log on the workstation as a member of the local Administrators group.
- Launch the Run dialog by typing [Windows key] + R.
- In the run dialog, enter REGEDIT in the entry box and select ok.
- In the Registry Editor, locate and delete the following subkeys. WARNING – This will delete all remaining Microvellum data.
- HKEY_CURRENT_USER\Software\Microvellum
- HKEY_LOCAL_MACHINE\Software\Microvellum
- Close the Registry Editor and restart your computer.
Related Articles
How to Install Toolbox AC (AutoCAD Companion)
Below is a systematic guide for installing Toolbox AC. Before installation, we recommend reviewing our Pre-Installation Instructions and System Requirements . Right-click on the Setup.exe file and select “Run as administrator”. Observe the initial ...
Uninstalling Toolbox OEM
These procedures explain the removal of Toolbox and supporting files while using Windows 10. Uninstalling Toolbox from “Apps and Features” Select the “Windows start icon”. Select “Settings”. Select “Apps”. ...
Preparing Your Computer to Install Toolbox
This tutorial demonstrates the steps recommend prior to installing Microvellum Toolbox and Toolbox AC (AutoCAD Companion). Prior to installing an update, we advise backing up your current data before initiating the process detailed below. Due to ...
Toolbox Standard 2023 Installation Best Practices
The following article contains the recommended and necessary procedures for installing Microvellum’s Toolbox Standard AutoCAD 2023. In order to get the smoothest and highest quality experience, it is recommended to be running a graphics card with 4 ...
Getting to Know the AutoCAD Interface
AutoCAD is the drawing platform for Microvellum. The AutoCAD interface can be completely customizable to suit your needs. The descriptions and images shown below are just an example of how AutoCAD can be configured. It is recommended to research best ...
Recent Articles
Toolbox Release Notes | Build 24.1.0719.642
The following release notes apply to Toolbox build 24.1.0719.642 900 Tools Fix A recurring issue with 900 tools being used in an incorrect order during certain operations was reported. The issue would manifest as tools switching back and forth during ...
Foundation Hardware Highlight: Grass
Microvellum’s Foundation Library is built on the premise of providing our users with the best quality hardware for their construction projects, be they commercial, residential, or anything otherwise. As such, Toolbox has hardware from multiple brands ...
Toolbox Release Notes | Build 24.1.0703.641
The following release notes apply to Toolbox build 24.1.0703.641 Product Comments Fix An issue with product comments in has been resolved. It was found that in older builds (pre-2023), when a formula driven product had comments placed into it and the ...
Foundation Hardware Highlight: Richelieu
Selecting an Azure VM to Deploy Microvellum
Selecting the correctly sized virtual machines (VM) in Azure depends on several factors, such workload requirements, budget, and performance requirements. It may be necessary to work closely with an IT professional with experience working in Azure to ...
