adding routes to nest
is there a way to add a route in a nest and have it run after the border route. we use an 1/8" bit to go back and clean out inside corners but it needs to be done after the part border is already cut. we created a 2 pass bit to do this because the smaller bit breaks too easy and it will break if we try to route that first before the border is cut.
hope this makes sense. looking for a quick solution if possible.
