Associative Machining Mirrored
I'm setting up a coat hook for some lockers we are going to run, and the machining works properly on the back and right gable but is somehow flipped when applied to the left gable. Not sure what is going on, anyone else have this problem before and what did you do to solve it? Feels unintuitive to have to make a separate piece of hardware just for the left gables...
You can see the drill pattern matches on only 2 out of 3
