Boring Divisions all the way through
Hi,
I was wondering if someone can point me to the right global setting to change the boring on divisions.
Right now the program wants to flip the part. I would like for it to bore it all the way through if the shelf holes match on each opening. example: if both opening have linebore with same parameters.
I've been having to "cheat it" in the nested sheets using the nest editing tool and manually adding the machining to bore thru.
thanks in advance!
